Bizhub 654e ,two strips on the touch panel after switching on.
  • pinspin
    • Oct 2011
    • 156
    [Electrical] Bizhub 654e ,two strips on the touch panel after switching on.
    Hello .After a power failure, the copier stopped functioning properly. After turning on two bands appear on the touch panel . We tried to replace all logic boards, but without result. The MFP board firmware update ends with a message = Not good = . We will be grateful for any advice.
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 654e ,two strips on the touch panel after switching on.
    Does the machine restart by its self?
    So it does get to the firmware upgrade menu?
    Whatever
    • Woxner
      • Jul 2011
      • 850
      when doing firmware load one file at a time. its pain but it should go. i have seen certain levels stop with this message if bizhub secure is done or sometimes the flash drives make a difference. but do try one at a time
      • pinspin
        • Oct 2011
        • 156
        The machine does not restart and does get to firmware upgrade menu.
        • Rvale
          • 83
          I have seen that before, when you update from some firmware versions you have to update the display as well, it's a different method but does the trick.
          • pinspin
            • Oct 2011
            • 156
            After Firmware Update we we get a message
            = Error. This is invalid External Memory . Please make sure the External Memory =
            = MFP Comtroller Download N.G. ( ADF , Scanner , Printer Download Completed ) =
            • jamesyboy
              toner monkey
              • Jul 2010
              • 188
              sounds like the sd board is cattle trucked
              • pinspin
                • Oct 2011
                • 156
                We replaced MFP board and NVRAM card - the copier is functioning normally .
