Error Code C-3452 on KM- C450
  • cpress
    • 37
    I just replaced the fuser unit and this code came up . How to i fix this code
    TIA
    David
  • RockETop
    Curmudgeon at large
    • Apr 2007
    • 171
    Search is your friend.....
    http://www.copytechnet.com/forums/ko...c-3452-a.html?
    http://www.copytechnet.com/forums/ko...zhub-c450.html
    • copy shop
      • 40
      List of Malfunction Resetting Procedures
      Different malfunction resetting procedures apply depending on the rank of the trouble code.
      * List of Malfunction Resetting Procedures
      Trouble Code Rank Resetting Procedures
      For details of Trouble Reset, see Adjustment/Setting below
      Setting / Procedure
      1.
      Turn OFF the Main Power Switch.
      2.
      Turn Main Power Switch ON again while hoding down the Utility/Counter key more than 10 seconds after.
      3.
      Touch [Trouble Reset].
      4.
      Check to make sure that [OK] is displayed below and then it has been reset.
      If ok is not there , it will show a different code....
      IF it says OK, you should be good to go.
      5. Just
      Turn off the Main Power Switch and turn it on again more than 10 seconds after, and make sure that the machine properly starts.
      Hope this helps
      Tammy
