Konica Minolta 754e
  • antone
    • Oct 2014
    • 344
    Konica Minolta 754e
    Tray 4 J -1401 new rollers and clutches..spring on reinforcement plate...konica bulletins !
    Sent from my SM-N920V using Tapatalk
  • allan
    RTFM!!
    • 5462
    Re: Konica Minolta 754e
    Try to take a steel blade to score the shafts where the oneway bearings run.
    Whatever
    • copyman
      Owner / Technician
      • Sep 2005
      • 4765
      Or scuff up shaft with scotch brite pad where one way clutches contact. Did you try new style "ribbed" pick up roller? Do you mean you followed tech bulletins or need any that pertain to this issue?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4765
        Just to be clear you are talking about the 1000 sheet tray at bottom right? Scuff up shaft with scotch brite pad where one way clutches contact. Did you try new style "ribbed" pick up roller? Do you mean you followed tech bulletins or need any that pertain to this issue?
        • antone
          • Oct 2014
          • 344
          1000 sheet ,I will give a try !tks
