Bizhub 185 Interesting printout issue
  • Obtex
    • Jan 2017
    • 22
    I got this issue i never seen before and i cant get it to print normaly again.
    On a text page it seems like theres a uneven toner density, but when i print the test page from service mode it shows some interesting patterns. (test page attached)
    I`ve tried to clean the laser unit, clean the whole copier, replaced the OPC cylinder, replaced the wiper blade, replaced the transfer roller. Tried to change Vg Ig voltages. Nothing seems to help.
    Can please someone help me?
    I need this copier to get working ASAP
    Scan.pdf
  • Flash
    • 378
    Re: Bizhub 185 Interesting printout issue
    Looks like a transfer problem. Try stopping the machine during a copy and see if you have a good image on the drum.
    • Synthohol
      Certified Konica Expert
      • 5463
      looks like what happens when generic toner is used.
      can you confirm OEM toner or dirt in a bottle?
      • Obtex
        • Jan 2017
        • 22
        It's a original toner.
        • Synthohol
          • 5463
          you said you replaced the drum, did you replace the developer too? try to always replace them as a set.
          • Obtex
            • Jan 2017
            • 22
            Yes did that too. And did a auto adjust atdc. No change
            Stopping mid print with the same test page - 2018 02 12 09 20 01 — imgbb.com
            • Obtex
              • Jan 2017
              • 22
              With the same test page.
              Ive replaced the transfer roller assembly... still this
              • Obtex
                • Jan 2017
                • 22
                Anyone?
                • mascan42
                  • Oct 2008
                  • 471
                  Definitely looks like a transfer issue. The lower part of the drum (before contact with the paper) is solid black but is spotty after that, so not all the toner is being transferred to the paper. Check the transfer roll, contacts & voltage.
                  • Obtex
                    • Jan 2017
                    • 22
                    I replaced the transfer roller, cleaned the spiky strip with alcohol , checked the connections
                    • tinnyjay
                      • Oct 2009
                      • 647
                      Originally posted by Obtex
                      Anyone?
                      If you changed drum and developer you have to have a look at the laser then.
                      "Who loves the roses,must also bear thumbs"
                      • D_L_P
                        Self Employed
                        • Oct 2009
                        • 1196
                        Anyone?
                        Have you changed the developer unit?
                        • Obtex
                          • Jan 2017
                          • 22
                          Dont have a unit on hand, but i did replace the developer itself.
                          • jqueen
                            • Jul 2015
                            • 45
                            Looks to me like a transfer belt and transfer roller issue. I had this same problem with a CS 400ci. Check to make sure that the transfer belt and roller are in contact with each other. It could be that the transfer roller guide on the transfer belt might be amiss...
                              • 22808
                              yeah looks like it could be the developer .. wonder what the counts are on the machine?
