Drum /Developer sign on panel in c6000
  • vijaysharma
    • Sep 2008
    • 61
    [Error Code] Drum /Developer sign on panel in c6000
    Hi,
    Can anybody explain how to remove Drum/Developer sign on operational panel of c6000, it's continue displaying on panel.
    Rgs
    Re: Drum /Developer sign on panel in c6000
    Originally posted by vijaysharma
    Hi,
    Rgs
    replace parts requested .. clear counters in service mode
    • vijaysharma
      • Sep 2008
      • 61
      I replaced the consumables and cleared the counter in service mode but still it's showing on display.
      Rgs
      • stuckmx
        • Nov 2017
        • 36
        Rgs
        you cleared both the consumables counter (special parts counter) for each consumable
        and the maintenance counter?
          clearly not correctly
          • Synthohol
            Certified Konica Expert
            • 5807
            you have to run the adjustments in the service manual, THAT will clear the message.
            • vijaysharma
              • Sep 2008
              • 61
              Which adjustment can you describe the steps
                RTFM
