skewd copy bizhub 600
  • Gulbadin
    • Nov 2017
    • 22
    [Misc] skewd copy bizhub 600
    when i copy on A6 paper the result is crooked skew on bizhub 600.on A4 paper the copy is fine
    • 23007
    Re: skewd copy bizhub 600
    Are you feeding A6 (International Postcard: 105 x 148mm/4.13 x 5.83 inches) paper from the bypass? That is the only tray capable of handling paper that small. And it must be fed SEF (105mm at the leading edge). The smallest paper that can be fed from the paper trays is A5 SEF (148 x 210mm/5.83 x 8.27). =^..^=
    • Gulbadin
      • Nov 2017
      • 22
      yes the paper is fed from bypass tray
        • 23007
        SEF? It doesn't look like it. =^..^=
