Konica Minolta Bizhub C558 SMB Scan doesnt work
  • Malmat
    Hello,
    even after hours of trying I cant get SMB-Scan to work... always connection Erros.
    I cant find any help at Minolta Homepage. Maybe someone can help after looking at my settings on the screenshots.
  • SARRA CARD
    Re: Konica Minolta Bizhub C558 SMB Scan doesnt work
    HELLO EVERYONE
    i've a wierd error code on our MGI DP60 PRO - it's the same process machine as KONICA MINOLTA 6500
    the error code is C-B680 , MGI Hotline said they do not have the code on their data base.
    Can anyone help please
    THANK YOU
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Originally posted by Malmat
      Hello,
      Thanks![ATTACH=CONFIG]38908[/ATTACH][ATTACH=CONFIG]38909[/ATTACH]
      I cant read this postage stamp sized image, and its not in english either.
      Your machine is also running old firmware / prior to function version 4 as it has the old web interface. Update the firmware and up the function version and take a better screen shot.
        • 8138
        Originally posted by SARRA CARD
        HELLO EVERYONE
        THANK YOU
        You'll get better results ny starting a new thread.
          HELLO EVERYONE
          THANK YOU
          this is a TOTALLY different problem than what the thread was started on....
          PLEASE START YOUR OWN DAMN THREAD!
          • Leyahné
            • Feb 2016
            • 44
            Hello,
            Hi please try using the computer or server name, do you use antivirus on that pc or server ?
            • Pandabeest
              • Nov 2016
              • 5
              Hello,
              Old firmware that only supports SMB1? Only SMB2 is supported on newer Windows editions. Firmware update?
              • Brad6784
                • Mar 2015
                • 75
                Hello,
                Firmware, I've had exactly this issue myself. Update with the latest firmware, problem solved! Good luck
