bizhub c368 hdd question...
  • n25an
    • Jul 2008
    • 1030
    quick question...
    I am replacing the hard drive in a bizhub c368 and am curious if I need to backup the settings to a usb before I replace the hdd or if I don't need to and can replace the hard drive and just perform the formatting procedure in the service manual...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • rrrohan
    • Sep 2011
    • 1977
    Re: bizhub c368 hdd question...
    Originally posted by n25an
    quick question...
    Always backup. Pretty sure you lose the address book and maybe user boxes
    • Synthohol
      Certified Konica Expert
      • 5822
      100% yes.
      change bit sw 72 to hex 04 hit fix.
      in admin mode system settings 3rd page i think is external memory backup.
      export to USB just make a simple password like "1" and save.
      replace HDD and upon boot you are asked to format it, hit menu then utility and the option should be right there IIRC.
      only takes maybe 2 minutes then install movie data again in system2 2nd page install data.
      then reimport all the data you just saved.
      total time maybe 20-30 min you will be done.
      • n25an
        • Jul 2008
        • 1030
        thanks
