bizhub 500
  • Nelson649
    • Aug 2017
    • 1
    bizhub 500
    j7216jams
  • kingarthur
    • 1342
    Re: bizhub 500
    correct .....what have you done to resolve it....
    • 3ktlc
      • Feb 2018
      • 180
      Re: bizhub 500
      Should be able to look that up in the manual.
      • Downunder
        • Aug 2007
        • 174
        Re: bizhub 500
        Check the finisher FS510 ? sensors or guide plates. Run copier without finisher attached see if fault goes.
