Looking for reliable c220 and c224e series dev & drum reset device
  • Don N.
    • Nov 2011
    • 409
    Anyone tried the reset switch/harness/device found on e-bay or elsewhere? We refurb & sell these machines so I don't just want to use life optimization or dip sw settings. I want to replace developer after it goes bad with aftermarket dv which has been working well so far, but we use too many reset chips. We also use new drums, blades & chargers to r/b the drum units, and they work good as OEM. Again, just burning through too many chips.
    I've googled & searched but not finding any strong tech endorsement of these devices. There's a pic of one from ktn with a part #, but I guess they disc. the item bc the ktn part# comes up invalid.
    Really would like to find one that does c220 & c224e series, drum & dev.
    Thanks!
  • rrrohan
    • Sep 2011
    • 1977
    Re: Looking for reliable c220 and c224e series dev & drum reset device
    Why not just disable consumable life reminder and set the to no stop.
    • Don N.
      • Nov 2011
      • 409
      When new developer is installed (aftermarket, with old dv unit) it needs to be calibrated and reset. Same with rebuilt drums. We aren't just ignoring or resetting units that are past life.
      • myster
        • Oct 2011
        • 79
        If you can
        We have one device built by us to reset drums and developers.
        • jabatt
          • Apr 2014
          • 15
          Thanks!
          I'm a Korean.
          I am making and selling.
          This is Pusan in Korea.
          It can be purchased through importers.
          Company Name: Daewoo OA System
          *konicaminolta bizhub C220/C280/C360 series dev & drum reseter
          *konicaminolta bizhub C224/C284/C364/C224e/C284e/C364e series dev & drum reseter
          • Don N.
            • Nov 2011
            • 409
            Originally posted by jabatt
            I'm a Korean.
            [ATTACH=CONFIG]39092[/ATTACH]
            [ATTACH=CONFIG]39093[/ATTACH]
            PLEASE direct me to the vendor. I want to try it.
            • Zoran
              • 52
              I think my project is better than others
              M RESET C224
              This unique M RESET C224 Device enables Technicians to reset Developer Units without changing existing TCR sensors. This device has unlimited number resets and can be used as an onsite tool or in a workshop based .
              Using:
              1.
              After installing compatible developers ,in the developer image unit, it is necessary to perform a reset of the developer image unit in order for the TCR sensor to remember the concentration of the toner the value triggers the toner supply.
              2.
              In the case of errors related to the concentration of toner - developer unit (C2551, C2553, C2555, C2557, C2411, C2412, C2413, C2414, C2552, C2554, C2556, C2558, C2559, C255A, C255B, C255C, C2561, C2562, C2563, C2564. .) and after the repair it is necessary to reset the TCR sensor.(If necessary, reduce or increase the concentration of toner in the developer from the service mode)
              Compatible with:
              bizhub C220/bizhub C280/bizhub C360/d-Color MF220/d-Color MF280/d-Color MF360/ineo+ 220/ineo+ 280/ineo+ 360
              bizhub C224/bizhub C284/bizhub C364/ineo+ 224/ineo+ 284/ineo+ 364
              bizhub C224e/bizhub C284e/bizhub C364e/d-Color MF222 plus/d-Color MF282 plus/d-Color MF362 plus/ineo+ 224e/ineo+ 284e/ineo+ 364e
              bizhub C454/bizhub C554/bizhub C454e/bizhub C554e/d-Color MF452 plus/d-Color MF552 plus/ineo+ 454/ineo+ 554/ineo+ 454e/ineo+ 554e
              bizhub C227/bizhub C287/bizhub 367/CM2041/CM2101/D300/D301/D310/D311/ineo+ 227/ineo+ 287/ineo+ 367/d-Color MF 223/d-Color MF283
              bizhub C258/bizhub C308/bizhub C368/bizhub C458/bizhub C558/bizhub C658 /d-Color MF254/d-Color MF304/d-Color MF364/d-Color MF454/d-Color MF554/d-Color MF654/MFX-C2590/MFX-C3090/MFX-C3690/MFX-C4590/MFX-C5590 /ineo+ 258/ineo+ 308/ineo+ 368/ineo+ 458/ineo+ 558/ineo+ 658
              bizhub C250i/ bizhub C300i/ bizhub C360i/ineo+ 250i/ineo+ 300i/ineo+ 360i
              bizhub C221/bizhub C221s/bizhub C281/ineo+ 221/ineo+ 221s/ineo+ 281
              bizhub C3350i /bizhub C4050i /ineo+ 3350i /ineo+ 4050i
              bizhub C3350/bizhub C3850/ bizhub C3850FS/d-Color MF3300/d-Color MF3800
              bizhub C4000i/ bizhub C3300i /ineo+ 4000i/ineo+ 3300i
              bizhub C3851/ bizhub C3851FS
              bizhub 224e/bizhub 284e/bizhub 364e/ ineo 224e/ineo 284e/ineo 364e
              bizhub 454e/bizhub 554e/ ineo 454e/ineo 554e
              bizhub 654e/bizhub 754e/ ineo 654e/ineo 754e
              bizhub 227/bizhub 287/bizhub 367/ ineo 227/ineo 287/ineo 367
              bizhub 308e/ bizhub 368e/ bizhub 458e/ bizhub 558e/ bizhub 658e
              bizhub 308/ bizhub 368/ bizhub 458/ bizhub 558
              With this tool you will no longer have to spend money buying chip because the tool allows you to reset as many times as you want and allows the use in other equipment infinitely resets the image Drum unit .
              The device reset drum unit allows the reset of the drum unit with a in numerous equipment of the , ie a single device can reset the drum unit more than a 72 million times and of without the need for a chip or an exchange of the chips.
              Using:
              1
              After replacing a compatible OPC drum.
              2
              Device also allows the use of black image Drum unit in place of the color image Drum unit .
              In addition to resetting the drum units the reset when permanently connected to the equipment allows the use of the drum unit K (Black) instead of the Drum unit color, ie you can buy to put in the equipment only Drum unit k (black) instead of the drum unit color thus having a huge economy since the Drum unit K (black) is much cheaper than the drum unit color.
              M RESET C224 allows to select an opc drum for reset using the switch.
              The micriswitch ON position allows resetting.
              In the position of the OF device, it can permanently remain in the device and replaces the chips of all drum units.
              (in the bizhub C220 series .. it can replace black and one color)
              M RESET can also reset toner status chips for C554e, C308...
              M RESET C224 has a light indication of a successful reset.
              • lomenadam
                • Jan 2023
                • 1
                But how is this actually work? Just some buttons and the cable or any electronics in there?
                I'd like to build one instead of buying it.
                [ATTACH=CONFIG]58628[/ATTACH]
                M RESET C224
                Using:
                1.
                2.
                Compatible with:
                Using:
                1
                2
                • Gift
                  • Mar 2011
                  • 2459
                  • Hansoon
                    • Sep 2007
                    • 3400
                    We get very good working drum and developer unit chips for all KonicaMinolta and Lexmark machines, so no need to fiddle around in front of the customer with any obscure looking tool.
                    Hans
                    • CP-1015
                      • Nov 2020
                      • 325
                      Is it allowed to introduce my Resetter here? The other two has "red cards".
                      • tsbservice
                        Field tech
                        • 8062
                        Better leave it for PMs from interested in...
                        • CP-1015
                          • Nov 2020
                          • 325
                          Thanks, it's difficult because the chances are greater in the forum, but I'll stick to the rules.
                          • Gift
                            • Mar 2011
                            • 2459
                            Hans
                            #notasuicidebomber
                            • CP-1015
                              • Nov 2020
                              • 325
                              Thanks!
                              Your PM box is full
