C500 Error Code 23-09
  • captkirk
    • 39
    We have a C-500 with a error code 23-09. Toner motor issue. M18
    We have cleaned out the Toner Collection Assembly. But still have the error code.
    Should a firmware update be used for this? Special firmware (65lac112CMV0)
    Any other ideas?
  • Albonline
    • Sep 2008
    • 1151
    m18 is the transfer belt motor. is cleaning unit full of hardend toner? is waste toner auger system cloged/broken?
    • captkirk
      • 39
      You are correct. Sorry.M-18 is Transfer belt motor.
      We have cleaned toner collection assembly and put back together. We have noticed no binding. Everything looks good after cleaning and putting back together.
      • captkirk
        • 39
        The cleaning unit is clean. No hard toner. Turn by hand freely.
        • Albonline
          • Sep 2008
          • 1151
          the auger system inside the copier is that locked up/broken?
          • Albonline
            • Sep 2008
            • 1151
            can you turn on m18 in the i/o mode?
            • captkirk
              • 39
              auger in clean.
              Yes the motor run freely.
              • captkirk
                • 39
                we ran code 41 & multi code 12
                noticed auger motor running great.
                Is there another that we should run?
                • Albonline
                  • Sep 2008
                  • 1151
                  does m18 phase disk / sensor work?
                  • captkirk
                    • 39
                    not familiar with that. How do you check it?
                    • ColorGOD
                      Check the drive gear on M18. They are plastic and if the toner tube got clogged at some point the gears might have stripped. Even if they look good they might be jumping. This will cause the toner to evacuate much slower and cause another backup.
                      • excanonguy
                        • Jun 2008
                        • 173
                        I was just wondering what the resolution for this problem ended up being?? I have one doing the same thing now.
                        • excanonguy
                          • Jun 2008
                          • 173
                          Back to the top
                          • BITC
                            • 6
                            I have a similar problem. How did you resolve this issue. please help
                            • Stirton.M
                              All things Konica Minolta
                              • Oct 2009
                              • 1804
                              Description
                              F23-10/SC23-10.
                              Solution
                              PROBABLE CAUSES:
                              1.The first transfer roller sensor (PS15) is detecting a malfunction in timing between the sensor and the transfer pressing/releasing motor (M19).
                              Check that all 4 transfer rollers (p/n 65AA26040 - Black, p/n 65AA26120 - colors) inside the transfer belt are seated properly in there respective front and rear
                              block holder assembles. Check the operation of M19 in the 47 mode, multimode 48, code 0, 2, and 3. Check PS15 in the 47 mode, multimode 48, code 0, 1,
                              2, and 3, for home position = 01; other than home position = 000.
                              2. The position of M19 is determined by PS15. If PS15 is out of place or faulty, M19 cannot find home position.
                              Note : When activated in 47 mode, M19 does not stop rotating.
                              Inspect PS15 (p/n 08AA 8551 2) and replace it if necessary.
                              "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                              ---Groucho Marx
                              Please do not PM me for questions related to Konica Minolta hardware.
                              I will not answer requests or questions there.
                              Please ask in the KM forum for the benefit of others to see the question and give their input.
