C-4521 / C-3103 / C-0305
  • madmom
    • Jan 2016
    • 3
    [Error Code] C-4521 / C-3103 / C-0305
    Hi to all,
    i'm trying to solve error code 4521 who appears 24hours after changing 250K Kit while the machine is in printing process, the first error code was C3103, after switching off/on the machine the error code 4521 appears.... and sometimes error code C0305!!!!??? any ideas please..
  • Guest
    Re: C-4521 / C-3103 / C-0305
    Originally posted by madmom
    Hi to all,
    C-4521.....color correction unit...ps 8 sensor....clean it throughly
    C-3103.....2nd transfer pressure motor M34...clean it .....at times the problem is with the door switch.
    The problem 3103 is intermittent.just clean the surrounding area
      • 23007
      Perhaps it would be pertinent to know what model that you're working on. =^..^=
      • shik
        Re: C-3103 /
        I have the same error 3103 and its not clearing I changed The M34 motor and still the error no clearing any advice pls
