c280 vs c284
  • ck1
    • 485
    c280 vs c284
    I just want to verify the drum ,dv , belt as the same or not ?
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: c280 vs c284
    NOPE. not even close.
    Intermediate Image Transfer Kit Yield (300,000) A0EDR71600
    Fusing Unit Yield (523,000) A0EDR72000
    DV311K Developing Unit - Black (Yield: 570K) A0XV03D
    DV311Y Developing Unit - Yellow (Yield: 114K) A0XV08D
    DV311M Developing Unit - Magenta (Yield: 114K) A0XV0ED
    DV311C Developing Unit - Cyan (Yield: 114K) A0XV0KD
    DR311K Drum Unit - Black (C360 Yield: 120K, C280 Yield: 100K, C220 Yield: 70K) A0XV0RD
    DR311YMC Drum Unit - Color (C360 Yield: 90K, C280 Yield: 75K, C220 Yield: 55K) A0XV0TD
    TN216K C280/C220 Toner - Black (Yield: 29K) A11G131
    TN216Y C280/C220 Toner - Yellow (Yield: 26K) A11G231
    TN216M C280/C220 Toner - Magenta (Yield: 26K) A11G331
    TN216C C280/C220 Toner - Cyan (Yield: 26K) A11G431
    Waste Toner Box Yield (45,000) A162WY1
    Image Transfer Kit Intermediate Image Transfer Kit (C554e,C554,C454e,C454,C368, C364e,C364, C308, C258:300K/C284e,C284:280K/C224e,C224:225K) A161R71333
    Fusing Unit Fusing Unit (C364e/C364/C284e/C284/C224e/C224: 590K) A161R71866
    DV-512K Developing Unit - Black (C554e/C554/C454e/C454/C364e/C364/C284e/C284/C224e/C224/554e: 590K) A2XN03D
    DV-512Y Developing Unit - Yellow (C554e/C554/C454e/C454/C364e/C364/C284e/C284/C224e/C224: 590K) A2XN08D
    DV-512M Developing Unit - Magenta (C554e/C554/C454e/C454/C364e/C364/C284e/C284/C224e/C224: 590K) A2XN0ED
    DV-512C Developing Unit - Cyan (C554e/C554/C454e/C454/C364e/C364/C284e/C284/C224e/C224: 590K) A2XN0KD
    DR-512K Black Drum Unit (C554e, C554,C454e, C454:95K/C364e, C364:90K/C284e, C284:75K/C224e, C224:55K) A2XN0RD
    DR-512 Color Drum Unit (C554e, C554,C454e, C454:95K/C364e, C364:90K/C284e, C284:75K/C224e, C224:55K) A2XN0TD
    TN-321K Toner Black (C364e/C364/C284e/C284/C224e/C224: 27K) A33K130
    TN-321Y Toner Yellow (C364e/C364/C284e/C284/C224e/C224: 25K) A33K230
    TN-321M Toner Magenta (C364e/C364/C284e/C284/C224e/C224: 25K) A33K330
    TN-321C Toner Cyan (C364e/C364/C284e/C284/C224e/C224: 25K) A33K430
    Waster Toner Box Waste Toner Box (Yield: 100K) A4NNWY3
    • ck1
      • 485
      Re: c280 vs c284
      ok thanks you
      • Don N.
        • Nov 2011
        • 409
        Re: c280 vs c284
        We rebuild our drum units for both.
        The drum cylinder is the same.
        The cleaning blade is the same, but on the 4's they have pads at the ends, so we are just ordering the 4 blade for both series to stock one part.
        KTN has chargers for each. They are different, and a MUST to get OEM quality results.
        Of course you have to chip them with their respective chips.
        Transfer belt assy's, belts & blades to rebuild them are all different.
        Dev's are sold as different, but the gram weight is the same, and
        GET THIS:
        We mistakenly used all 3 colors c364 DV in a C220 and it worked. We got a magenta high TCR code a few days later, but we have had intermittently with c220 DV reset chips lately, and going back with an OEM good TCR fixed it. So we are of strong opinion that the DV is the same, but remember the 4 series has dev in the toner, constantly replenishing and purging for longer DV life vs. a c220.
        • allan
          RTFM!!
          • 5462
          Re: c280 vs c284
          For fun try a DV-110 on the C224's with the grooved mag rollers.
          Whatever
          • Don N.
            • Nov 2011
            • 409
            Re: c280 vs c284
            I'll submit that to KMBS and wait for their approval.
            • allan
              RTFM!!
              • 5462
              Re: c280 vs c284
              good luck
              Whatever
