Bizhub C452-652 Toner replacement with other models!
  • parsmehregan
    • Jun 2012
    • 97
    Hi
    Due to lack of bizhub c452 toner cartridge in the market (around here) and some other reasons ,is it possible to fill it's cartridge with bizhub 8500 or other models ! Does anyone have any experience in toner replacement with other Models? if so,does it have any effect on print quality and what's the overall procedure.
    Any idea and suggestion in this issue would be appreciated.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4546
    Re: Bizhub C452-652 Toner replacement with other models!
    I wouldn't try it. If you are having a hard time finding toner then what will it be like finding an image unit after you ruin it with the wrong toner! If that desperate use aftermarket toner "for that model" or at least use other "2" series toner. Much better chance of NOT killing those expensive IU's.
    • AjitN
      • Mar 2009
      • 287
      Originally posted by parsmehregan
      Hi
      you can use it without any problem, just watch for CQ for first few thousand prints to be on safer side.
      We have been using it.
      • allan
        RTFM!!
        • 5459
        Can you find C451 or C550 toners?
        Whatever
        • AjitN
          • Mar 2009
          • 287
          Do not use aftermarket toner, instead use OEM 6000 OR 8000 toner, which is cheap, & do not damage machine.
          • Ahmed Bushara
            • Mar 2015
            • 26
            for bizhub C451 you can use type 216 that used on KM C280 it should be genuine one.
            Thanks and best regards
            Ahmed Bushara
            Electronic Engineering technician
            Mobile: +249-999198804 /+249-123198804
