C-DO12 error
  • swaggen
    • Sep 2017
    • 100
    C-DO12 error
    I was rewriting the drive to attempt to fix a job fail issue.... I conducted a format and received this code. The Fax unit was removed by my old tech as a horse trade because he needed it for another job and I would never use it.
    I believe now after the Format the printer is looking for it, How do I keep the start up from looking for it?
  • jasoon88
    • Feb 2018
    • 3
    Re: C-DO12 error
    In service mode, I believe in system 1, option board unset fax 1
    Sent from my LG-H831 using Tapatalk
    • B0265
      • Jan 2007
      • 718
      Re: C-DO12 error
      Did you do a logical format of the HDD?
      • swaggen
        • Sep 2017
        • 100
        Re: C-DO12 error
        Nope physical. Do I need to update firmware? I have no idea how to do that.
        • Synthohol
          Certified Konica Expert
          • 5808
          Re: C-DO12 error
          As mentioned above turn off fax circuit 1
          Also a logical format is in order. It only takes like 2 minutes. The physical one takes hours.
          Then make sure hdd is turned on in service mide.
          Reinstall movie data.
          That should be it unless the HDd is no good.
          Never do a physical format. Waste of time.
            • 14590
            Re: C-DO12 error
            I have looked through several service manuals and failed to find a C-D012 error code. What machine are you dealing with.
            For your own information C-D codes are related to HDD and C-B codes are related to fax.
            I suggest you do a logical format and install movies data as synthohol suggested. That should fix it up.
            • swaggen
              • Sep 2017
              • 100
              Re: C-DO12 error
              I did a failed attempt to update the firmware and the issue resolved itself. So weird.
              • B0265
                • Jan 2007
                • 718
                Re: C-DO12 error
                You must do the logical format after the physical.
                • Asaadahmed003
                  • Jun 2019
                  • 24
                  Re: C-DO12 error
                  A late reply but someone might need it
                  What i do to fix this code is:
                  1- unset the fax unit
                  2- do a logical format for the HDD
                  3- uninstall the HDD
                  4- turn off then on the machine
                  5- install the HDD back
                  And that's it, it should fix the code 😊
                  • djdn
                    • Jun 2021
                    • 9
                    Re: C-DO12 error
                    No such luck. Any other ideas?
                    • nathicana
                      • Aug 2008
                      • 329
                      Re: C-DO12 error
                      When Konica Minolta machines go back to the leasing company I run "overwrite all" in the administrator menu and sometimes get the dreaded D012.
                      If you have already done a logical format do the firmware and it may resolve the code.
                      You can also try uninstalling the hard drive which I think is under system 2 in technician mode but functionality may be affected.
                      The bigger machines like a C754e seem especially prone to D012 codes after a physical format or data overwrite.
