biz 250
  • Gab
    • Aug 2015
    • 668
    biz 250
    Machine shows M4.
    Can i replace only drum and not developer at this point?
    If i can , i reset IU only PC life ?
    I will replace developer later .
  • copyman
    Owner / Technician
    • Sep 2005
    • 4612
    Re: biz 250
    They have to be done together. Then run F8. If you try and replace just drum you will get the dreaded 2557 code. There are a lot of posts on this forum about this.
    • laitang
      • Nov 2012
      • 627
      Re: biz 250
      You can if use toner not genuine.
      You can change copy kit counter to "mode 1" and M4 disappear!
