Time out error on C654 large jobs.
  • Synthohol
    Certified Konica Expert
    • 5857
    #16
    Re: Time out error on C654 large jobs.
    just to make sure there is NO Fiery correct?
    if not all you need is movie data which i can link you to and explain how to install if you dont know. even without it there is no affect on usage.
    • swaggen
      • Sep 2017
      • 100
      #17
      What about program data? Seems like I'm asking for trouble clearing all of this.
      I have no idea how to "save" any of the data
      • Synthohol
        • 5857
        #18
        start from page 2
        • swaggen
          • Sep 2017
          • 100
          #19
          start from page 2
          Under data initialization , clear all data?
          • swaggen
            • Sep 2017
            • 100
            #20
            Its asking for the encryption passphrase to the HD and the admin password is no longer 1-8
            • swaggen
              • Sep 2017
              • 100
              #21
              Reformatted drive, it came back to life. Job had a time out error. Same job to good computer and it is printing.
              • swaggen
                • Sep 2017
                • 100
                #22
                At this point quite honestly I would change bit switch 72 to hex 04 and backup everything through admin mode and then in the system and you go to initialization and do a full system data initialization basically it sets the machine back to factory and once you reboot re-import the data through admin mode so you don't lose any addresses and try it once again this way it refreshes it's like refreshing the operating system on your computer that's what I would try next if this was my call good luck
                From what I can tell I like the Fiery, as Its processing a job its immedialtey spitting out the job and printing... while still processing. If this what a fiery does, I will slap one on each of my 654s
                  • 30356
                  #23
                  Correct driver? what print driver are you using and is the port setup correctly? Please provide more details
                  printing from what OS
                  all Pc's doing it or only one?
                  You should be using PCL6 driver setup standard tcp/ip port port 9100 raw and uncheck snmp
                  Do not use WINDOWS drivers
                  Don't use the konica universal driver
                  • swaggen
                    • Sep 2017
                    • 100
                    #24
                    One PC, Proper drivers, Windows 10. I have no idea the ports, a tech came yesterday and looked at all of the. ... 3 techs and many on lines posts. Goose eggs
                      • 30356
                      #25
                      Install the correct driver PCL6 from Konica and setup port correctly.
                      • swaggen
                        • Sep 2017
                        • 100
                        #26
                        As of yesterday I believe we have the PCL6 . What is required to select the right port? which one is right?
                        • Synthohol
                          • 5857
                          #27
                          RAW port 9100 for konica controller
                          LPR port 515 for Fiery with the word "Print" as the queue name.
                          • swaggen
                            • Sep 2017
                            • 100
                            #28
                            Synthohol,
                            I did as instructed when wiping out and initializing the machine back to default. I can no longer get into the admin settings with 1-8 enters. Its says the password does not match. Have you seen this happen before?
                            • patk
                              • Jun 2008
                              • 56
                              #29
                              Try 1234567812345678.
                              Its the default on later models
                              • rrrohan
                                • Sep 2011
                                • 1977
                                #30
                                Its twice as secure lol
