Konica Minolta code C-E006
  • Bamba Diop
    • Aug 2025
    Hi All,
    I have a KM C8000 wich gives me headache.
    I have C-E006 code. Did Firmware update bur no result. the code appears after printing or copying around 6 pages.
    I have read in the sm it could be OACB board faulty.
    Any Hekp?
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: Konica Minolta code C-E006
    PROBABLE CAUSES:
    1. Firmware bug or possible failed Memory Control Board/1. (bizhub PRESS C8000 only)
    Confirm that firmware is version 20 or later. The Memory Control Board/1 (p/n A1RF H020 02) may need to be replaced.
    bit switch 2-0 Set this switch to 1 after installing the optional hard disk to recognize the connection of the hard disk to the copier. (if installed)
    hope these solutions from KM help.
