Konica Minolta bizhub 162
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Hi
    Not familiar with Minolta.I want to replace the drum. Is anyone so friendly and tells me if I can buy and replace the complete unit? I would not like to change the blade and drum in the field for the first time....
    • 14972
    Re: Konica Minolta bizhub 162
    Originally posted by zoraldinho
    Hi
    It looks the same as a BH181. If it is you can order the IU but it doesn't come with drum or dev. These need to be ordered separately and installed into the IU. Then you would need to install it into the machine, clear drum and dev counter and run an F8. I would suggest you try to find a service manual.
    If it isn't the same as a BH181 then disregard all of the above.
    • Synthohol
      Certified Konica Expert
      • 5892
      4519-601 is the drum unit part#
      8936-488 bag of developer.
      Simple Google search
      If the DV unot itself is bad you will have to get a part number from someone across the great pond as that model is not sold in the USA.
      • Toxic
        • 698
        In Europe we use this parts numbers
        A08ER70100 IU Assy
        8936493 DV-110
        4021029701 DR-114
        Synthohol
        This appear to be DR-113 and dont fit to Bizhub 162 as i know...
        • zoraldinho
          • Mar 2008
          • 5018
          A08ER70100 IU Assy
          8936493 DV-110
          4021029701 DR-114
          Synthohol
          Great info Thanks!
