Biz Hub C452 Error c-2553
  • Copies Unlimited
    • Jul 2025
    [Error Code] Biz Hub C452 Error c-2553
    Machine will not work error code C-2553
    I have changed the Magenta Drum from another working copier and the message will go away for several copies the then comes back again.
    I have replaced the Magenta toner, anyone have any ideas?
  • mincopier
    • Dec 2015
    • 289
    Re: Biz Hub C452 Error c-2553
    Check and make sure the hooper is supplying toner.
    • MR. ZENITH
      Good day everyone. Please someone should help me out. My Bizhub 452 suddenly started producing loud notice each time I tried using the bypass. But other trays are not doing so. What could be the problem?
      • tsbservice
        Field tech
        • 8007
        Wrong thread.
        Better start your own thread. Actually may help you and others with your problem.
          you just dug up a two year old thread that has nothing to do with your issue.
          please STOP digging up threads 2 years and older and start a new thread listing ALL issues...page counts...consumable counts... error pages..what you have done to try and fix it.
          • Synthohol
            Certified Konica Expert
            • 5822
              Kitten Killer! [emoji28][emoji1787]
