c3350 Shows jam at right hand door and FF FF code
  • Elmo
    • Feb 2010
    • 541
    Hi all
    Just had a used C3350 traded in
    Machine displays a Jam at the right hand door and code FF FF anyone come across this
    Have checked paper path sensors and switches all seem ok
    Any advise would be welcome Thanks
    I Used To Live To Fix Things Now i Fix Things To Live
  • joelea
    • Feb 2012
    • 64
    Re: c3350 Shows jam at right hand door and FF FF code
    Originally posted by Elmo
    Hi all
    Id be trying firmware have you got any?
    • 3ktlc
      • Feb 2018
      • 180
      I agree on trying firmware. We just had a C3851fs jamming and firmware took care of it.
      • Elmo
        • Feb 2010
        • 541
        Turned out to be a hardware fault
        was a broken wire to the exit sensor
        • n25an
          • Jul 2008
          • 1030
          which firmware did you use to fix this issue... ???
          Sad To Say I Don't Have a Life
          I do this stuff on the weekends too
          • n25an
            • Jul 2008
            • 1030
            C3851Series_A92E0Y0-F000-G00-N5.exe
            Release Date: 6/26/2017
            Version: G00-N5
            was this the firmware ??
            • 3ktlc
              • Feb 2018
              • 180
              Pretty sure that was it.
              • R.guillermo
                • Dec 2021
                • 5
                • Synthohol
                  Certified Konica Expert
                  • 5804
                  its PS7.
                  • R.guillermo
                    • Dec 2021
                    • 5
                    Originally posted by Synthohol
                    its PS7.
                    God bless you again thanks for the previous help from my heart, I was already checking the sensor and all the rest in that area and the connectors and their cables and even replaced some since I have another equipment of that for feet but the paper jam error FF -FF still there is help please
                    • R.guillermo
                      • Dec 2021
                      • 5
                      God bless I managed to clear the paper jam error and now it is the 2152 error that is causing me annoyance but I am trying to solve it some help
                      • Synthohol
                        • 5804
                        3.5.14 2152
                        (1) Contents
                        (2) Procedure
                        Step Action Control signal Location of electrical components
                        1 Check the connector between M1-PRCB CN9 for
                        proper connection and correct as necessary.
                        2 Check the connector of M1 for proper drive coupling
                        3 Check the connector between PS9- PRCB CN12 for
                        4 Check the connector between SD1-relay CN85-PRCB
                        CN12 for proper connection and correct as necessary.
                        5 PS9 I/O check, sensor check PRCB CN12-3 (ON) 15-C to D
                        6 SD1 operation check PRCB CN12-12 (REM) 15-E
                        7 M1 operation check PRCB CN9-3 to 6 15-B
                        8 Replace M1 - -
                        9 PRCB F4 conduction check - -
                        10 Replace PRCB - -
                        N.1. bizhub C3850/C3350N.2. bizhub C3850FSS.12. 2152)
                        • R.guillermo
                          • Dec 2021
                          • 5
                          3.5.14 2152
                          (1) Contents
                          Trouble type 1st transfer pressure/retraction malfunction
                          Trouble code 2152
                          Rank B
                          Detection timing • The 1st transfer pressure sensor (PS9) does not change its state from one corresponding to the retracted
                          position to the pressed position within a predetermined period of time after the 1st transfer pressure solenoid
                          (SD1) has been energized.
                          • The 1st transfer pressure sensor (PS9) does not change its state from one corresponding to the pressed
                          position to the retracted position within a predetermined period of time after the 1st transfer pressure solenoid
                          Trouble isolation -
                          Relevant electrical parts • Main motor (M1)
                          • 1st transfer pressure sensor (PS9)
                          • 1st transfer pressure solenoid (SD1)
                          • Printer control board (PRCB)
                          (2) Procedure
                          8 Replace M1 - -
                          10 Replace PRCB - -
                          • Link to the wiring diagram (N.1. bizhub C3850/C3350)
                          • Link to the wiring diagram (N.2. bizhub C3850FS)
                          • Link to the layout drawings for related parts by each trouble code (S.12. 2152)
                          God bless you, thank you, I was able to solve this but I have a paper jam error 11-02 in tray 1 and the paper does not even come out of the tray and in tray 2 the paper is halfway through and it gives me an error 30-03
                          • Synthohol
                            • 5804
                            Tray 2 sounds like a paper size mismatch and the 11-xx in tray 1 just change the rollers and make sure the backstop for the paper actually helps push the paper towards the rollers when lifted.
                            I've put a piece of sponge behind the mylar for additional support when lifting.
                            • tsbservice
                              Field tech
                              • 7981
                              I think those paper trays were modified heavily because of falling apart and paper jams.
