BH454e Missing 1" wide section of print front to rear.
  • DSharpe
    • Apr 2018
    • 36
    #16
    Re: BH454e Missing 1" wide section of print front to rear.
    So the data is missing in the void crossfeed, and the page image aligns on all four edges? =^..^=
    The data is indeed missing in the void cross feed. If you notice the sheet on the bottom that void has actually moved a little more to the right of the page. The entire image is there with the exception of that void which may happen once a week or once a month.
      • 23003
      #17
      Ok, let's start with what it's not:
      It's not primary charge, or anything to do with charge or drum ground. Any charge loss would be indicated by black areas, not voids.
      It's not a drum drive or registration drive problem. The image is correctly registered on the paper (if not all there).
      It's not a charge cleaner issue, which would be in the feed direction.
      Hey, what if one of your LTR feed units was overdriving and making a Z-fold, imaging, then opening the Z-fold before fusing ... nope, that doesn't work. It would shift your trail edge registration.
      It's unlikely to be be developer drive or transfer charge loss. It would happen more frequently, have varying proportions, and not have crisp edges or clean voids. You'd also see toner density symptoms like low developer density codes or add toner indications.
      This leaves the laser unit, image processing board(s), and HDD.
      Does that narrow it down a little? =^..^=
      • DSharpe
        • Apr 2018
        • 36
        #18
