I know, silly question, but.....
  • Hansoon
    • Sep 2007
    • 3382
    ..... what the hell is the purpose of the orange led indicator above the blue one at the left front side on most bizhubs?
    Customer called me that the orange indicator is steady on though the machine is working well.
    Hans
  • eccelobo
    • 113
    Re: I know, silly question, but.....
    Hans
    Status Indicator
    Indicates the status of this machine by the lamp color, flashing, or a lamp lighting up.
    Flash in orange: Warning
    Lights up orange: The machine has stopped.
    Enviado desde mi SM-G920V mediante Tapatalk
    • tsbservice
      Field tech
      • 8008
      20. Warning indicator.
      About This Machine
      • REGSIS
        • May 2016
        • 435
        Preventive maintenance message will turn ON orange light and machine will run without problem.
        • femaster
          • May 2011
          • 1501
          If the orange LED is lit, there is going to be some sort of message on the copier screen. Tell your customer to watch the screen for a short bit, might be just one message, or could be multiple which copier will display 1 at a time generally. Without knowing model, it's hard to say where to look, but generally near the top left on the screen.
          As REGSIS stated, most likely cause is some sort of PM message.
          • Hansoon
            • Sep 2007
            • 3382
            Thanks guys. It's a BH-363 and I shouldn't be so lazy but go to the customer and see what's going on...... Could imagine that the image unit is near the end of its life. If only they where no so far away from my office......
            Hans
            • allan
              RTFM!!
              • 5462
              SW 51 F0 and 55 0C will help with the warning lights.
              And P or L code will cause that.
              Whatever
              • rrrohan
                • Sep 2011
                • 1977
                If you have it connected to CSRC just check on that
