Konica C6501 developer problem
  • stakid
    • Jan 2013
    • 2
    [Misc] Konica C6501 developer problem
    Hi
    I have the problem you see in the pictures only in magenda developer.
    The problem started suddenly and only in the front edge. The rest print is very good.
    Some one with the same problem?
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: Konica C6501 developer problem
    there is something behind the shutter or doctor blade or one of the magnets inside the mag roller has been dislodged.
    did you recently change the DV? did you take out the screw disengage the shutter and spin the roller to help expel any debris as its vacuumed?
    • stakid
      • Jan 2013
      • 2
      No i have never changed developer.
      Today i will change it and i will do a good clean.
      If it is a magnet problem do i have to change the roller?
      Thanks.
      • Toxic
        • 698
        This is well known problem on this machines,toner depleting.
        I dont think something is damaged phisicaly.
        What is developer life now?
        Just change developer as you plan and try use this settings from troubleshooting.
        • danetime
          • Jul 2014
          • 8
          As said replace Developer.
