koinca minolta c3100p lines on copy.
  • brent
    • Nov 2008
    • 1212
    I probably put this in the wrong section.. but I will include pics of the lines this little hummer is leaving
    it has 300 prints on it.. it was fine then it started putting just almost solid magenta lines on it.. I replaced
    drum now its the same but cyan.. what have I got going on? any thoughts
    thank you all so much
    brentwallacelib.pdf
    hopefully the file updated thank you
    • 23008
    Re: koinca minolta c3100p lines on copy.
    Notice that there's no yellow? I'd replace the yellow drum. It's shorting out the HVT. =^..^=
    • brent
      • Nov 2008
      • 1212
      I will certainly try that.. thank you
      brent
      • spree
        • Jun 2012
        • 211
        Hello,
        - all 4 new drums
        - genuine toners all time of usage
        , but not good printing.
        What is your opinion?
        - Transfer belt? I do not have another one, to change it :-(
        - Voltage problems?
        - Lasers problems?
        • Gift
          • Mar 2011
          • 2459
          Is that elliptic thingy supposed to appear on the first page?
          • spree
            • Jun 2012
            • 211
            Yes, its supposed to be there those elliptic things.
            • allan
              RTFM!!
              • 5462
              brent[ATTACH]39505[/ATTACH]
              Wow that page hurts my head. Did B.C's advise to change yellow work if you can still remember?
              Whatever
              • allan
                RTFM!!
                • 5462
                Originally posted by spree
                Hello,
                - all 4 new drums
                - Voltage problems?
                - Lasers problems?
                Those are the worst sample pages to print to try and get an idea there.
                Then save the snapshot of it as a PDF so we can see the thing.
                Download and print a color test chart.
                Whatever
                • spree
                  • Jun 2012
                  • 211
                  Here, bettercp3100.pdf sample
                  • allan
                    RTFM!!
                    • 5462
                    Here, better[ATTACH]47911[/ATTACH] sample
                    Will have a good look at the transfer roller in the path and the belt. Take those out and take a pic of both the roller and the transfer belt. Its not the laser. You can see the void valleys from the texture of the paper were the transfer is to weak to make the toner jump another 10 microns more. Remeber something about transfer pressure timing?
                    Whatever
                    • spree
                      • Jun 2012
                      • 211
                      I gave out int. transfer belt and make photo, and make photo of transfer roller, but now I remember, I changed this spring: A6DR702701 in coveyance section: it could be the possibility of poor printing quality?
                      After the side cover is closed, the conveyance mechanism put the transfer roller down. Which is the right position of transfer roller after closing side cover? Up or down?
                      I make paper jam (open the side cover, when it printing) and the transfer roller was up.
                      I make paper jam and put out itb. transfer belt and the picture at the ITB before reaching transfer roller was at poor quality. What do you think? The customer did not changed the drums (and he lie to me?)
                      • allan
                        RTFM!!
                        • 5462
                        Except for the ding in the belt, both roller and belt looks ok. The picture with the image on the belt shows that the transfer is bad. Looking at that most of the image stays on the belt and does not get transferred.
                        Make sure the HV makes proper contact. Also make sure the roller is pressing against the belt. The gears to lift the roller could be installed out of position.
                        Sure those ellipses on the sample print should be there?
                        Whatever
                        • spree
                          • Jun 2012
                          • 211
                          Yes elipses are in the picture printed from computer.
                          • spree
                            • Jun 2012
                            • 211
                            You wrote: Looking at that most of the image stays on the belt and does not get transferred.
                            I wrote: The picture at the transfer belt is BEFORE it reaches transfer roller! It is transfered right from drums!
                            • allan
                              RTFM!!
                              • 5462
                              Will have to disagree with you on that statement. It can't develop an entire image on the belt before transfer.
                              The image you got there was on the top of the belt. The transfer belt cleaning blade will be next in line.
                              Right from drums wrong from belt to paper.
                              Whatever
