Bizhub c454e Scan to Gmail issues
  • Qball
    • Jun 2013
    • 127
    [Misc] Bizhub c454e Scan to Gmail issues
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub c454e Scan to Gmail issues
    which SMTP server are you using? smtp-relay.gmail.com or smtp.gmail.com or aspmx.l.google.com
    cause if your using aspmx.l.google.com you can only send to gmail users and if you tried to send to anyone else it would give a server connection error
    • copier tech
      • 8220
      I always start by updating to the latest firmware when faced with this issue. I have dozens of Bizhubs both 'e' & non 'e' using gmail without any issues.
      • Qball
        • Jun 2013
        • 127
        • Qball
          • Jun 2013
          • 127
          That thought crossed my mind.
          • Bix
            • Apr 2018
            • 1421
            I had a similar problem.
            The "problem" is from Google. In reality it is not a problem but a level of security that has most likely been enabled.
            You make sure that they have not enabled double verification. Also go to Google> My account> Access to Google. Infondo check that "Allow less secure apps:" is ON.
            Greetings
            • guitar9199
              • Sep 2016
              • 1100
              I know this sounds dumb, but change your DNS settings to.....
              Primary : 8.8.8.8 and Secondary: 8.8.4.4
              Sending with Gmail, I've had this fix issues quite a few times.
              • rrrohan
                • Sep 2011
                • 1977
                Greetings
                He said he had in OP that was my first thought though also
                • mincopier
                  • Dec 2015
                  • 289
                  Check this from Konicaminolta
                  Dropbox - Scan to Gmail.pdf
