Konica minolta/canon c620 error code c-3102
  • jumeda33
    • Jul 2015
    • 55
    Re: Konica minolta/canon c620 error code c-3102
    Originally posted by K-3
    to reset a fuser code you need to get into service mode believe #3 system setting, then software switch setting and set dipswitch #3-1 from a 1 to 0 turn off then on. there is no trouble reset screen on the C6500.
    Hi K-3,
    Thank you sooooooo much for your information. I was able to get to where I needed to be but ran into a little trouble. I wouldn't even have got this far without your help as I kept looking for that Trouble Reset thing. I am attaching a picture of where I got to but I don't understand what numbers to put where. If you could guide me I would be very grateful. Also, my other question is this. Do you have to do the reset even if you change the gears and shaft or will it just know that it is fixed? I would like to try the reset just to see if it comes up.
    Thanks for all your help so far. I really appreciate it and you are making me look good to my boss as well.
    David
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      Originally posted by jumeda33
      Hi K-3,
      David
      [ATTACH=CONFIG]39582[/ATTACH]
      If it's a fuser code it will not clear on it's own. The software switch thing is a hold out from the old Konica's basically it's a safety function. You might get lucky and reset the code and will run fine, but generally the code happened for a reason.
      Your story reminds me of a customer that asked us to work on their Ikon C550(i believe that's the model). After seeking advice from techs on this forum, we turned it down. Ultimately it may have cost us a sale of additional production machines, but we don't work on them so I don't like to promise to fix things I cannot guarantee to fix.
      • Toxic
        • 698
        @jumeda33
        Set dipsw as shown on the your edited photo,hit return button and restart machine.
        If code appear soon again you must search for problem,propably fuser sensor.
        Do not try to reset this error multiple times because you can cause bigger problem and it is not safe,cause for error must be solved.
        • jumeda33
          • Jul 2015
          • 55
          #19
          Originally posted by Toxic
          @jumeda33
          Hi Toxic,
          Thanks a million for that info. That was great. Don't know how you did it but it was awesome and exactly what I needed to know. In case you didn't figure it out already, I am not a tech. I am an employee with mechanical experience. I used to repair our old Oce 9800 machines after Oce would no longer service them. This is why I need detailed information like you guys have provided. It seems like the general consensus is the 3 white gears and the shaft that is causing the problem. Thanks to Synthohol, he posted part numbers for these. I am going to the office this morning and will give it a try and I will keep you guys posted. Thanks again for returning my image with such awesome details.
          David
          • Synthohol
            Certified Konica Expert
            • Mar 2016
            • 5852
            #20
            those white gears are one way gears, take special care to install them in the correct direction.
            • jumeda33
              • Jul 2015
              • 55
              #21
              Thanks for that. Hopefully there is a way for me to tell which way is right. I just tried the reset and got the same code. I guess its on to ordering the gears and shaft. I will keep you guys posted. Cant thank you guys enough for the help so far.
              David
              • jumeda33
                • Jul 2015
                • 55
                #22
                Hi guys,
                I have a new update since my previous post of resetting and it not working. After I posted that I had another idea. I reset it one more time. Then I took the cover off so I could see the gears. Then I turned the machine back on so it could initialize. I saw the round silver motor looking thing spinning as well as all of the gears, except the two white ones that you guys have been referring to. So, it coded again of course. Oh, forgot to mention that before I did all this I tried to turn those gears by hand and they were very hard to turn. I know they won't go in one direction but they were hard to turn the other way. Felt like they were almost stuck. I did get them to turn so I was hoping by getting them to go by hand then the machine would work. Nope, no go. Does this tell you guys anything?
                Thanks again for all your help.
                David
                • Synthohol
                  • Mar 2016
                  • 5852
                  #23
                  Spray IPA on the gear axles and rotate using the motor. Sometimes that will temporarily allow proper grip on the one ways just to confirm but I'll bet it is
                  Them.
                  • jumeda33
                    • Jul 2015
                    • 55
                    #24
                    Them.
                    I am betting you are right so I am going to order them with the info you provided me. thanks a million again and I will let you know how it goes.
                    • K-3
                      service technician
                      • Feb 2018
                      • 51
                      #25
                      The silver spinning thing is the fuser drive motor, it rotates in both direction. one-way to feed paper thru and the other is to provide pressure for the lower roller, that is what the oneway gears are for. you also have a one-way gear on the upper roller for the fuser belt. most likely the C3102 code is the 3 white gears, but i have had a bearing lock up on both the lower and the upper rollers that also cause jamming, but also thru the fuser code. so if you still get a code after replacing the gears check them.
                      • jumeda33
                        • Jul 2015
                        • 55
                        #26
                        Hi K-3,
                        Thanks for the tip. Hopefully it's just the gears everyone is describing. I was wondering if anybody has a .pdf of the service manual so I can sort of follow along as I am taking it apart and trying to repair it.
                        thanks.
