bizhubC454e Cannot Scan via SMB to Windows 10
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Jamming] bizhubC454e Cannot Scan via SMB to Windows 10
    We have a Konica Minolta bizhubC454e that just will not scan to a Shared Folder on Windows 10 via SMB (Server Connect Error every time)
    We Tested it with Windows 7 SMB (via Hostname & I.P.) and Email (Gmail) - BOTH WORK GREAT/Fine
    We Accessed the Shared Folder from another computer and placed a new file JUST FINE/OK
    Troubleshooting Methodology:
    We are ONLY Using a Windows 10 LOCAL Profile (we are familiar with the new "Microsoft Email" profiles not supporting SMB)
    We are ONLY Creating a Shared Folder directly on the ROOT Drive (Drive C: - not buried in "My Documents")
    Trouble Reset on Copier performed
    Network Data Reset on Copier performed
    Connected the Copier to the Network via DHCP and Static (Manual)
    Verified all DNS Settings and the Gateway
    Verified ALL CREDENTIALS for Windows 10 Profile
    Disabled ALL Firewalls
    Disabled ALL Anti-Virus and Malware protection
    Used I.P. Address instead of Hostname
    Formatted "All Destinations" on Copier and Re-Created Destination
    Copier Settings Related to SMB:
    Network/SMB Setting/SMB Server Setting is set to SMB 1.0/SMB 2.0
    Network/SMB Setting/Client Setting/SMB Authentication Setting is set to NTLM v1/v2
    Firmware Version:
    MFP Card Version A5C10Y0-F000-G00-C8(00)
    MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00)
    MFP Controller Linux Base Linux-2.6.26.8-rt16
    MFP Controller Kernel Program A5C10Y0-1C00-G00-42
    MFP Controller SubSet A5C10Y0-1F00-G00-F1(00)
    MFP Controller A5C10Y0-0100-G00-C8(00)
    Operation Panel Message Data A5C10Y0-8100-G00-C4
    Fax Board Controller1 A22M0Y0-4000-G00-08(00)
    Fax Board Controller2
    Fax Board Controller3
    Fax Board Controller4
    Engine Parameter A5C00Y0-0054-G00-00
    Engine BOOT A5C00Y0-0055-G00-00
    Scanner A5C10Y0-0023-G00-30
    Printer A5C00Y0-0050-G00-21
    ADF A3CE0Y0-0024-G00-10
    Finisher A3EP0Y0-0071-G00-19
    RU
    ZU
    Panel CPU A55V0Y0-8900-G60-00
    DSC1
    DSC2
    Loadable Device Driver1
    Loadable Device Driver2
    SD A3ER0Y0-0071-G00-08
    Voice Data
    Movie Data A5C10Y0-C000-G00-30
    Dictionary Data A5C10Y0-B100-G00-00
    OCR Library
    Panel Sound Data A5C10Y0-C200-G00-00
    MFP Controller Thread Image Parameter A5C10Y0-8B00-G00-01
    MFP Controller PIC Image Parameter A5C10Y0-8A00-G00-01
    MFP Controller System A5C10Y0-1000-G00-C8(00)
    MFP Controller Print Controller A5C10Y0-3000-G00-T3
    MFP Controller Print Controller Font A5C10Y0-3F00-G00-T0
    MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-01
    MFP Controller MIO A5C10Y0-5000-G00-B8(00)
    MFP Controller PIC A5C10Y0-8200-G00-41
    Last edited by MFPs R Now PCs; 05-01-2018, 11:42 PM. Reason: forgot a troubleshooting method we tried
    It does not matter how slowly you go as long as you do not stop. –Confucius
    • 14719
    Re: bizhubC454e Cannot Scan via SMB to Windows 10
    Firmware Version:
    RU
    ZU
    DSC1
    DSC2
    Voice Data
    OCR Library
    Make sure computer's network location is either "Work" or "Private". Make sure password protected sharing is off.
    If that doesn't work, try creating another user on the computer with a password, change the name of the copier to that name. Turn on password protected sharing. Make sure the new user is an admin account.
    • MFPs R Now PCs
      • Jul 2011
      • 156
      I guess I missed listing some things in my troubleshooting methodology:
      Network is set to Work/Private (Yes/Verified/ALWAYS) <-TOP ISSUE with customers saying I cant scan to my computer (it's on Public)
      Password Protected Sharing ON (Yes/Verifed)
      Create Another ADMIN User/Profile (Tried this too)
      Trying with Password Protected Sharing OFF Now (with a LogOFF/LogON).... Result - Failed (Server Connect Error)
      Tried Turning Off the "HomeGroup/Let Windows Manage" by switching to "Use User Accounts & Passwords" - Failed
      -THANK YOU FOR YOUR HELP THOUGH!
      Last edited by MFPs R Now PCs; 05-02-2018, 12:25 AM. Reason: forgot to add detail/s
        • 14719
        Do you have the network error code being displayed? It is a numerical code the can narrow the problem down.
          • 30213
          Windows has disable SMB1 scanning do to security issues. On recent updates
          Use filezilla server on windows 10 machines or konica ftp utility
          • Woxner
            • Jul 2011
            • 848
            you can set this to use smb2 and it might work. you will need to changea soft sw to enable
            • MFPs R Now PCs
              • Jul 2011
              • 156
              It's Windows 10 HOME see -> Scan to folder windows 10
              Is THAT a problem that it's HOME not Pro now? GREAT!
              Any thought there, please?
              • Qball
                • Jun 2013
                • 127
                  • 30213
                  Originally posted by Qball
                  We’ve seen a lot of this. If you go to control panel and select programs and features then select turn windows features on and off, scroll down to the SMB 1.0 box. Check all the boxes within. Click okay then reboot the pc. This will get SMB 1.0 back online. Just for laughs, I’ll create a new self signed certificate on the MFP, as well. Typically this gets things moving again.
                  Turning SMB1 back ON is NOT RECOMMENDED
                  Microsoft's position on Server Message Block version 1 (SMB 1) in Windows systems is that organizations should just get rid of it.
                  That position has become crystal clear after SMB 1 proved to be a conduit for a ransomware outbreak this week. The ransomware, dubbed "WannaCry," used leaked hacking-tool code, purportedly from the U.S. National Security Agency, that targeted a Windows SMB 1 flaw. One of the "owners of SMB" at Microsoft, Ned Pyle, a principal program manager in the Windows Server high availability and storage group, had warned about continuing to use SMB 1 back in September in a TechNet article titled, "Stop Using SMB 1."
                  • MFPs R Now PCs
                    • Jul 2011
                    • 156
                    Thank you for this comment as security is needed for customer requirements AND our liabilities.
                    • mo0651
                      • 1054
                      Have your authorized Konica Minolta rep upgrade the firmware and special firmware to use SMB 2.0 & 3.0.
