Ikon ccp550 pro 80 Fiery server workstation 4 password.
  • jmart77
    • Mar 2006
    • 71
    Neither I nor the IT manager can find this code. The workstation 4 ask:
    Admin password
    User Password
    Guest -----------.
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: Ikon ccp550 pro 80 Fiery server workstation 4 password.
    Fiery.1
    • jmart77
      • Mar 2006
      • 71
      Tried that first? Didn't work. Has it been changed?
      • Synthohol
        • 5824
        likely, did you try blank?
        use command workstation and import this .ps file to the DIRECT queue, it will print the fiery password.
        • jmart77
          • Mar 2006
          • 71
          Ok, So I download this) transfer this to a disk or drive) load it into the Fiery)
          1.Because I'm in GUEST mode I can Transfer the Data?
          2. If so I can't print in Guest mode.
          • Synthohol
            • 5824
            operator never needed a password, it should be blank. you can use the import file feature in CWS as operator.
            maybe as guest, i never tried.
            • Desert Rat
              • May 2008
              • 1089
              Synthohol,
              Thank you for your assistance. Jmart77 and I are working on this together. I was unable to go over to this customer
              but Jmart did and he had trouble getting through the web page, but he was able to accomplish this task using a thumb
              drive. He plugged it in and it downloaded the file and printed out the password at the bottom of the page. I was told
              by another that it had to be LTR and not LTR-R. The password was at the bottom of the page. It was more than 30
              characters.
              Thanks again, we had just sold this machine last week and were sweating this one but thanks to you we were
              able to pull it out of the fire and the customer is happy again.
              DR
              And thanks to Jmart77 for being persistent and not giving up.
              • Synthohol
                • 5824
                happy to help
                • Desert Rat
                  • May 2008
                  • 1089
                  ME too!
                  DR
