BH C454 Duplex issue
  • G6token
    • Feb 2018
    • 19
    Re: BH C454 Duplex issue
    sounds like a diverter solenoid isn't firing properly or at all
    • G6token
      • Feb 2018
      • 19
      Where is this diverter solenoid located?help appreciated.
      • suomi
        • Oct 2008
        • 152
        Maybe Clutch is broken?? A161M20202
        • G6token
          • Feb 2018
          • 19
          I see no diagram or any sign of this part using that part number
          • tech51
            • 846
            Could you tell us the jam code it shows in the data?
            • Synthohol
              Certified Konica Expert
              • 5905
              replace the whole exit unit with the gate and solenoid.
              bit of a job but after the 3rd one it takes 10-15 minutes.
              or... on the left (front) side of the diverter gate there is a rubber pad used to dampen sound. just remove it. sometimes the gate fin gets stuck to it.
              • G6token
                • Feb 2018
                • 19
                I replaced the complete exit unit. Same issue occurring.
                • Synthohol
                  • 5905
                  Damn. That's a bottle of WTF
                  if you try to duplex a meter sheet does it still fail?
                  Even on a factory modded exit unit I've had to add a thick mylar in front of the solenoid pintle to keep the gate slightly engaged so the solenoid always fires correctly.
                  In your original post you said you replaced the duplex unit. Did you mean exit?
                  • tech51
                    • 846
                    As I said previously, what jam code is being registered in the data?
                    It could provide a clue.
                    • MVPunisher
                      • 209
                      Synthohol is correct. I have battled that exact issue multiple times. Typically replace exit unit and/or add the mylar. I have had to add the mylar on new ones too.
                      • suomi
                        • Oct 2008
                        • 152
                        Old number A161M20201
                        • suomi
                          • Oct 2008
                          • 152
                          If jam code 9310,9202
