KM 1060 with IC-415
  • Drcopy
    • Jan 2017
    • 57
    KM 1060 with IC-415
    I have a fiery that all of a sudden stopped working, there is power it and the Lans are flashing but get a "controller unconnected" message on the control panel.
    I have rebooted and restarted and suggestions guys?
  • Drcopy
    • Jan 2017
    • 57
    Re: KM 1060 with IC-415
    Oh by the way, no leds coming up.
    • tech51
      • 846
      I would try reloading the Fiery controller first.
      • Synthohol
        Certified Konica Expert
        • 5904
        is the green power button lit?
        • Drcopy
          • Jan 2017
          • 57
          No.
          • Synthohol
            • 5904
            what happens when you push it in for 3 seconds?
            • Drcopy
              • Jan 2017
              • 57
              Nothing really just the lan leds turn off then flash again.
              • Synthohol
                • 5904
                check the HSF and mount.
                • byronf
                  Senior Member
                  • Sep 2017
                  • 109
                  What version of system software have you loaded?
                  I had the same issue with Version 1.2 then I reloaded version 2.0 then ran the 19 patches and it connected after 10 minutes after machine booted.
                  • Synthohol
                    • 5904
                    his green power button does not stay lit if i understand this. that means either a fan isnt turning or a bad PSU or the cpu is overheating.
                    it sounds like the fiery is just protecting itself or the power supply is tanked.
                    • Drcopy
                      • Jan 2017
                      • 57
                      I think it might be a power issue, if there is no led's on, except the LAN activity led.
                      would you replace the cpu or the power supply?
