C 3100 p stuck in initializng
  • Kent
    • Feb 2018
    • 17
    [Electrical] C 3100 p stuck in initializng
    C 3100p stuck in initializing
  • Kent
    • Feb 2018
    • 17
    Re: C 3100 p stuck in initializng
    tried removing the network connection, and restating to no good, tried unplugging letting rest and then plug everything back in, still nada
    • arahael
      • Mar 2013
      • 97
      There is tool called nvram restoration tool
      • allan
        RTFM!!
        • 5459
        Transfer belt or IDS problem?
        Whatever
        • tech51
          • 846
          Last one I had like this it was the ssd board. It is an orderable part and has no set up procedure. Just swap it out and off you go.
          • allan
            RTFM!!
            • 5459
            Could be i guess, remember now that i had one do that.
            Problem went away after i replaced the 3.3v battery for a time and date problem?
            Whatever
