bizhubc452
  • brahim2222
    • Dec 2011
    • 9
    bizhubc452
  • Flash
    • 378
    Re: bizhubc452
    Have you cleaned the print heads?
    • allan
      RTFM!!
      • 5462
      Re: bizhubc452
      What P-codes do you get. Need to see half tones..
      Whatever
      • brahim2222
        • Dec 2011
        • 9
        Re: bizhubc452
        p21
        L1
        L2
        L3
        D1
        • brahim2222
          • Dec 2011
          • 9
          Re: bizhubc452
          I have already tried blue imaging ;unit laser; unit transfer belt ; but the problem persists
          • darry1322
            • Oct 2010
            • 817
            Re: bizhubc452
            Try running skew reset. You may need to replace the LSU driver board. That solved a similar issue I had with front-to-back registration on a C452.
            I actually replaced the belt sensors at the same time as the driver board, but I'm pretty sure the driver board was the issue.
            • Synthohol
              Certified Konica Expert
              • 5846
              Re: bizhubc452
              l1,2,and 3 are you need to replace the C M and Y image units, dont chip them like a cheap ripoff thief, replace them with OEM. D1 is usually a dirty slit glass or the white strip it calibrates from.
              p21 is failure to calibrate registration.
              im sorry if i sound like a primadonna but chipping consumables is just theft to me. if your click charge does not cover the cost of these units over time you must be a lousy businessman. if it does cover the cost with profit at the end you are just a thief trying to get more money. how do you sleep at night?
              my comments arent directly at you, i just see tons of chip reset posts and it make me cringe. if you only use OEM, thank you for your proper service.
              • Crusher
                • Jan 2018
                • 17
                Re: bizhubc452
                Colors are Cloudy too, replace image units, can sometime help with Color shift otherwise, under Untility Key, then Adminstrator mode goto expert mode and fix registration manually. Procedure is in the Service Manual.
