C308 with IC-416 Fiery - cannot connect to controller
  • jr84
    • Aug 2010
    • 17
    [Misc] C308 with IC-416 Fiery - cannot connect to controller
  • Synthohol
    Certified Konica Expert
    • 5804
    Re: C308 with IC-416 Fiery - cannot connect to controller
    Public with login has to be enabled, which means that the device in Papercut™ needs an Advanced Configuration setting change, ext-device.konica-minolta.skip-setup set to Y. This prevents Papercut™ from turning off Public Access. When setting up the Public account, restrict all functions not tracked except printing.
    2. Print without Authentication should be set to Allow or Full Color/Black
    3. Authentication to Active directory (or whatever authentication system is used) has to be set up on the MFP. Use Active Directory with NTLMv2 setting
