Press C6000, the Fusing Belt sticks and wraps sheets of low-weight paper.
  • Henriquelv
    • Jul 2025
    [Jamming] Press C6000, the Fusing Belt sticks and wraps sheets of low-weight paper.
    The Fusing Belt sticks and wraps sheets of low-weight paper.
    Hello, I would like to thank the entire CopyTech team and its members here, I have learned a lot from you.
    Here's another riddle.
    The Fusing Belt is fastening and curling the sheets at the time of the merger.
    See attached photos.
    Status
    - Fuser Roller Lower [new]
    - Fuser Up Rollers 1 and 2 are still in good condition.
    - A1DUR74H00 - Fusing Separation Plate Assy [new]
    - A03U736100 - Fusign Belt [new]
    The problem occurs with fine paper, 90 / 115g, on prints with high toner charge / density.
    Impressions with low or blank charge the problem does not occur.
    The machine always printed normally under these conditions, the problem is recent.
    Thanks for listening. I look forward to your opinions.
