Updating fw via ftp
  • pez
    • Jul 2015
    • 19
    Updating fw via ftp
    We've traditionally installed new fw via USB, but want to move across to using ftp.
    I've got a test machine in front of me (c454e) and we've created an ftp server that is (or appears to be) working. FTP server has no firewall/av for testing purposes, and we can access the files within it across the network without needing to log in (set to anonymous authentication, and Everyone and Anonymous is set as a security permission with read access).
    I've created a .tar of the fw using the bat file in the firmware download, and placed that tar file in the root of the ftp.
    My service mode settings are as follows:
    Service Mode
    Machine Update Settings
    Internet ISW
    Internet ISW Set
    Function Setting = ON
    Open Mode Setting = ON
    FTP Setting
    Data Aqcuisition Setting = ON
    Connection Setting
    Port = 21
    Connection Time Out = 1min
    PASV Mode = OFF
    Forwarding Access Setting
    User ID = blank
    PW = blank
    URL = my ftp server
    Filename = name of .tar file created by bat file in download
    When I go to the Download section and click Download, I get an NG message (no error codes). When I attempt to download via
    "Admin mode -> Network -> Machine Update Settings -> Internet ISW Settings -> FTP Server Setting ->
    Firmware Update Parameters" I see it says Failed in the Firmware Download Status box after I click Firmware Download.
    Do I also need to set proxy setting for FTP in "Admin mode -> Network -> Machine Update Settings -> Internet ISW Settings -> FTP Server Setting" via a browser? I've tried both with the proxy server address entered here and left blank here, but I get NG when
    I've tried switching basic authentication on in iis on my win10 machine and using an account name and password (which allows me to log into the ftp from other PCs using my credentials), and tried with it off (allowing a completely anonymous login - no credentials required), but both result in NG in the Download section.
    Copier is on a static IP, ftp appears to be OK, wondering what else I can look at to get this working. Does anyone use FTP to update the fw on these machines?
  • feracampos
    • Jul 2021
    • 40
    Re: Updating fw via ftp
    Service Mode
    Internet ISW
    Internet ISW Set
    FTP Setting
    Connection Setting
    Port = 21
    PASV Mode = OFF
    User ID = blank
    PW = blank
    URL = my ftp server
    Interested on this too.
    • techsxge
      • Jan 2022
      • 660
      I had it working once, have not used it because ftp is extremly unsafe even as a local server. The ftp protocol is nearly 40 years old and even Microsoft tries to stop using it by now, the same company that uses their printer spooling mechanism since XP.
      I'll give it a little try tomorrow and see if i can dig up my documentation to do this.
      There are safer ways than ftp tho
      • JasonSBE
        • Apr 2014
        • 184
        What OS are you running? Windows 10 built-in firewall disables ftp requests by default. May need to make sure that ftp traffic is permitted.
          • 37488
          OS of the computer is a mute issue as he is talking about sending firmware by FTP to a KM c454e. IMHO it is an extremely bad idea. The amount of damage that a hacker can do by accessing that FTP server is unlimited, and that includes using it as a backdoor into your entire network.
          • rrrohan
            • Sep 2011
            • 1977
            try setting credentials instead of leaving it blank.
            we used to always use credentials but i havent bothered using it for many years as was really only used instead of CF cards.
            I seem to recall retrying it on the 8 series but since firmware isnt just a single TAR file anymore i wasnt sure what to point it to so gave up
            • techsxge
              • Jan 2022
              • 660
              Finally someone here who understands the risk of having a ftp server in your network even locally... ILY
              • JasonSBE
                • Apr 2014
                • 184
                How is the OS an moot issue? The computer is where the firmware file is transmitted. Therefore, the OS that computer is running is relevant. And yes, FTP is not a safe method of updating firmware if you're doing it across a network, but you can still setup a FTP server a computer, and plug it directly into the MFP with a patch cable, and put manual network settings on both the MFP and the PC and update using internet ISW via FTP. I did it all the time on the old C353/C253/C203 systems because we had a lot of issue getting CF cards that would work.
                  • 37488
                  He was not talking about send to the computer, he was talking about sending firmware from the computer to the copier. A free FTP client is built into nearly every OS and can be accessed from the command line in any Microsoft OS.
                  • JasonSBE
                    • Apr 2014
                    • 184
                    Yes. The file is TRANSMITTED from the computer. Ergo, if the computer is running windows 10 or possibly even 8 and definitely 11, he should check the firewall settings.
                      • 30216
                      Updating the firmware of this machine
                        • 37488
                        With most major corporate and school IT departments have worked with, if they found out that the c454e was on their network with an enabled FTP server, that c454e and any other piece of equipment would immediately be replaced by equipment from another vendor and everyone from the company pez works for would be permanently banned.
                        • techsxge
                          • Jan 2022
                          • 660
                          well well, and then you hear someone saying school IT departments are stupid and old fashioned when it comes to security... Doesnt sound like it.
                          Thumbs up to any IT departments that does this. They are deffo on the right path.
                            • 37488
                            That depends on the school. I worked with high school and elementary school districts. They had to be good in order to deal with teachers. My daughter is a Computer Science and Engineering Professor at a Cal State University. The only person at the IT Department that they trust to touch the Computer Science computers is a former student of hers.
                            • techsxge
                              • Jan 2022
                              • 660
                              aaaaaand this makes me happy to hear too, since all schools i worked with seems to never had their knowledge of IT updated since well the 2000's to say it politely. I have some better swearwords on hand rn but i dont feel like thats appropiate right now. You know what i want to say i hope.
                              Heads up to your daughter then, she must be doing one heck of a job then.
