scan to usb current settings
  • Bix
    • Apr 2018
    • 1421
    Hello, a question perhaps stupid.
    In copying and scanning, I can set the default settings (ie the current settings).
    But I have difficulty finding a similar option for scanning to usb. The customer would like to black by default and not the color scan.
    Do you know how to set this up?
  • Synthohol
    Certified Konica Expert
    • 5905
    Re: scan to usb current settings
    i dont think there is a setting for that. it takes literally 1 second to hit auto color and change to black.
      • 15011
      Set it to black then go into utility- user settings= scan/fax settings- default scan/fax settings- current settings- okay.
      • Bix
        • Apr 2018
        • 1421
        lol, I suffer from a short memory.
        I have the same problem, trying to rediscover my old thread.
        However I still haven't been able to find an option that allows me to set the default black and white in the scan to usb.
        @copier addict your solution is correct but concerns the normal scan. Unfortunately this does not affect scan to usb.
        • Bix
          • Apr 2018
          • 1421
          I succeeded!
          You insert the USB stick. At the top right there is "Check settings". Now a popup comes out. You press "Use current settings".
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            Since it wasn't mentioned anywhere in this thread for some reason and is important.
            This only applies to 7/8 series and later. The 4e series does not have this option.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
