Konica Minolta C253 Prints B&W
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C253 Prints B&W
    Hi
    Got Konica Minolta bizhub C253
    If print 20 color pages, around 14-15 prints color and the rest prints B&W. Sometimes Demo page also prints B&W.
    Please advise.
    Thanks...
    • 14972
    Re: Konica Minolta C253 Prints B&W
    Originally posted by mearmi
    Hi
    Please advise.
    Thanks...
    Remove the transfer belt and clean the IDC sensors.
    • AjitN
      • Mar 2009
      • 287
      Hi
      Please advise.
      Thanks...
      Actually I am not very clear about Problem statement.
      Is it that if you send the job of 20 pages, first 14-15 pages are ok in color and next few pages are in black OR there are intermittent black copies/prints at any places.
      Also in case of black prints, does it print all image correctly in black OR data in color is missing. If data in color is missing then it could be ITB OR Belt retract clutch as first transfer rollers are away from drums. If all data is in black it is IMAGE PROCESSING fault which could be right from printer driver to PRCB.
      Hope this helps
      • mearmi
        • Oct 2010
        • 350
        Thanks for your reply
        3 colors are missing.
        please find the attached image.
        • magicaljake
          • Jun 2018
          • 22
          strange. that is clearly still supposed to be a 4 color demo page.
            • 14972
            Having seen your example I would say the transfer belt is the culprit. Try a new transfer belt. and roller.
            • AjitN
              • Mar 2009
              • 287
              Either Transfer Belt OR RetractClutch which drives first transfer roller within Belt Assembly for colors.
              • mearmi
                • Oct 2010
                • 350
                Many thanks for your prompt response. Please find the attached image of Retract Clutch and advise. This is the one we have to replace?
                • Andysnave
                  • Jul 2018
                  • 5
                  Yep that's the culprit. Good luck as it's buried deep in the machine.
                  • srvctec
                    Former KM Senior Tech
                    • Oct 2009
                    • 827
                    If the primary transfer clutch was the culprit, there should be a C2152 code since PS31 wouldn't be able to detect retraction. We had this happen on more than one occasion way back when and there was a bulletin that came out with a change to the pawl on the belt and a lever on the machine causing the issue.
                    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                    • mearmi
                      • Oct 2010
                      • 350
                      Replaced the transfer belt and Roller. Worked one day and got same problem again.
                      Please advise.
                      • Synthohol
                        Certified Konica Expert
                        • 5892
                        check all the HV terminals and springs for damage or even corrosion yet?
                        • mearmi
                          • Oct 2010
                          • 350
                          Thanks for your reply. Replaced the belt, machine worked for one day but same problem again. Which lever on the machine was causing this problem?
                          Please advise.
                          Regards,
                          • srvctec
                            • Oct 2009
                            • 827
                            Please advise.
                            Regards,
                            Are you not getting a C2152 code? I'm shocked you're not getting that code with the symptoms you have.
                            It's actually a bracket, not a lever like I mentioned before. But all of what I suggested is only for the code C2152. If you aren't getting that code, there must be something else going on since the sensor involved would detect every single time when the primary transfer rollers move. I really don't know what else to suggest at this point.
                            • mearmi
                              • Oct 2010
                              • 350
                              No i m not getting any code
