C454e faint lines in the cross feed direction in hafltones
  • cpyfixer
    • Oct 2008
    • 11
    We have a C454e that produces faint lines in the halftones of single colors. Shows up in test prints from service mode too (see attached). The customer was printing black and white photos and noticed the issue. We have a C364 at our office that produces the same effect. I've tried printing the haftone test pages from service mode at a value of 70 from several customer machines in the 4 series and see this issue on some and not on others. Seems pretty common, but most customers never notice. I tried calibration, drums, and transfer belt assembly, with no change.
    I suspect some sort of vibration in the drive, but not sure where to start there. The machine runs quiet and smooth. If I lay a hand on the vertical path door while it's printing, I don't feel anything out of the ordinary.
  • mo0651
    • 1054
    Re: C454e faint lines in the cross feed direction in hafltones
    Did you clean the laser slit glass?? We have had a couple of laser units cause something like that.
      • 23010
      At what interval does the pattern repeat? If it's a roller or gear divide by π (pi) to get the diameter of the roller causing it, UNLESS it's a developing issue. The mag roller counter-rotates, so the interval will not match the diameter of the developing roller. =^..^=
      • cpyfixer
        • Oct 2008
        • 11
        Got this resolved by replacing the registration roller along with the bushings and gears in the registration unit.
