c3100p toner missing
  • tech51
    • 846
    I have a couple of c3100p printers that intermittently come up with the message. toner missing. It can be any one toner or two or more of them. The customers seem able to reset the message(not sure how) but it keeps coming back.The detect pins on the machines seem ok.Has anyone experienced this before?
  • tekhed
    • Aug 2013
    • 20
    Re: c3100p toner missing
    Fixed in this engine firmware....
    [Download File name]
    A6DR-0Y0-0050-G00-1800.zip
    PRI_ DLBT1501960EN.docx
    1. Changes
    The following issues have been fixed
    Wrong error message "TONER MISSING CHECK YMCK"_bhC3100P. [ IQBD__1400774387]
    • endr_93
      • Oct 2022
      • 3
      1. Changes
      Hello. Can you explain to me how I can download and install this firmware? Many thanks
      • tekhed
        • Aug 2013
        • 20
        I don't think this firmware is publicly available
        • techsxge
          • Jan 2022
          • 660
          Having a similiar error (customer and myself cant get rid of the message). Solution i came up with until i figure out whats the cause:
          Put the Toner in another machine and print 5-10 Pages. After that, Toner works fine in the problematic machine.
          Wasnt firmware, thats for sure. Maybe the board is fcked.
          • femaster
            • May 2011
            • 1482
            The G00-1800 firmware was released 4-15-2015 (or 15-4-2015 for you backwards folks). It's readily available in the firmware repository on Konica's service site. Be advised there have been 10 newer firmware versions released since that date, with the latest being on 3-24-2021 (24-3-2021).
            • Tech09
              • Apr 2020
              • 144
              Remove the DC power supply and clean the spring contacts, use a scotchbrite pad lightly on them and the ends of the springs.
