Do all the toners have the same shape?
  • Bix
    • Apr 2018
    • 1421
    Hello,
    I have a curiosity. Some customers have different A3 printers. It could happen that someone of them was wrong to insert a toner?
    For example, can a customer insert the toner of a bizhub 458 into a bizhub 308? Or do the toners have small differences in shape to avoid this? Or the MFP alert?
  • kingarthur
    • 1363
    Re: Do all the toners have the same shape?
    The toner bottles are different...but the toners are probably the same, as the developer is the same, though the toner bottles are different, you can bet that your customer will make it fit,....we've had customers fit C220 toner into a C224, and it has worked without any problems at all, until we get a call that the "customer can't remove the toner bottle"....
    • Bix
      • Apr 2018
      • 1421
      Thank you!
      When you block then how do you remove them?
      • kingarthur
        • 1363
        Originally posted by Bix
        Thank you!
        With great difficulty........
