Bizhub C220 firmware update
  • tonyckma12
    • Nov 2020
    • 7
    #31
    Re: Bizhub C220 firmware update
    Originally posted by gideon
    I don't know anything about firmware in Europe.
    I know that here in the US there is different firmware for Yellow or red dots next to the lens.
    Good luck
    Would you please to send me firmware for C220.
    I just replaced my MFP with error code C164.
    Thank you in advance.
    tonyckma12@gmail.com
      wow first post and begging for firmware.. and NOT even a contributor
      • gideon
        • 283
        #33
        I sent it to your email, let me know if you didn't get it.
        Make sure that you install the right firmware, yellow or red dot by the lens are different firmware.
        • tonyckma12
          • Nov 2020
          • 7
          #34
          Thank you for your help, I hope my C220 will be resurrected and function normally.
          • tonyckma12
            • Nov 2020
            • 7
            #35
            My c220 located in Hong Kong but the new MFP is from US. I will try if the firmware is applicable.
            • mlauff
              • Jan 2021
              • 3
              #36
              Hello,
              we are a non-profit sports club (Startseite >> TSV 1895 Oftersheim e.V.) and a company gratefully provided us their "old" bizhub C220.
              Since quite some time, we unfortunately can't connect it to the network properly. From what I read we need the latest firmware.
              Can anyone please make this available for us?
              Thanks, and warm regards,
              Markus
              • copier tech
                • 8144
                #37
                Originally posted by mlauff
                Hello,
                Markus
                We can supply you with the latest firmware, drop us an email.
                However, if the only issue you have is not being able to connect the copier to your network its most likely only a setting issue.
                Log in as an administrator & change the TCIP settings to DHCP, allow the device to pick up an ip address, when it does install the printer driver using this IP address.
                Firmware Update - Printer & Copier Firmware
                • Hansoon
                  • Sep 2007
                  • 3385
                  #38
                  Hello,
                  Markus
                  • mlauff
                    • Jan 2021
                    • 3
                    #39
                    Thanks for the quick answer.
                    The issue is, that our firmware only has SMB1 which Windows 10 and our NAS no longer supports (disabled for security reasons). So, my hope is, that the newer firmware will support SMB2/3.
                    Warm regards, Markus
                    • Hansoon
                      • Sep 2007
                      • 3385
                      #40
                      • copier tech
                        • 8144
                        #41
                        Unfortunately no update was released for SMB 2/3 support for the C220 series.
                        However it does support SSl with a firmware update so you can scan to email using most clients (gmail for example)
                        This maybe a work around for you.
                        • mlauff
                          • Jan 2021
                          • 3
                          #42
                          Hallo Hans,
                          Thanks for this information. As the PCs and the FritzBox do not have a FTP server (and I don't want to install it on each machine), I'll try to get a cheap NAS for that.
                          Warm regards,Markus
                          P.S. The email you sent, did you replace "Vorname.Nachname" with "markus.lauff"? Anyhow, I changed the text of the Impressum to make it more obvious.
                          • Hansoon
                            • Sep 2007
                            • 3385
                            #43
                            • Metasfrastiki
                              • Mar 2022
                              • 4
                              #44
                              Hello,
                              I recently change the main board in my Konica Minolta BizHub C220 and after that it gave me a error C164.
                              If somebody can send me the Firmware i would be grateful!!!
                              mike.zotos@gmail.com
                              • copier tech
                                • 8144
                                #45
                                Originally posted by Metasfrastiki
                                Hello,
                                Happy to help drop us an email.
                                www.CopierFirmware.co.uk
