konica C454e
  • kttyhwk
    • May 2018
    • 12
    konica C454e
    Cannot web browse into machine, firmware has been updated
    Re: konica C454e
    wow such a wealth of information!
    can you ping or print to it?
    what error do you get on the PC after entering the ip addy into your browser URL bar?
    is this a new situation or has it been on going?
    did you hook up your laptop to the machine and try to access the RUI?
    • srvctec
      Former KM Senior Tech
      • Oct 2009
      • 827
      Re: konica C454e
      Also, what web browser are you using because that sometimes makes a difference.
      Provide us enough information so we can actually help if you really want help. Kind of like taking your car to a dealer and saying, "It doesn't drive right." Details matter!!
      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
      • Synthohol
        Certified Konica Expert
        • 5854
        Re: konica C454e
        In admin under network look for PSWC and make sure it's on.
        • kttyhwk
          • May 2018
          • 12
          Re: konica C454e
          your tough phil, i can ping it, i can print to it, i could browse to it before their network people got to it. initialize cleared all memory, installed new firmware, tried laptop. don't get an error just says cant find. using google chrome as web browser
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1257
            Re: konica C454e
            If you used to be able to access the web interface and all of a sudden can't access it/get an error that browser cannot display the Konica RUI webpage, the first step would be to try a different browser, if another browser could successfully access it , it's a browser issue. Could there have been a chrome update that changed some settings?
            If using a different browser does not work, you are going to have to figure out what their network people changed.
            • kttyhwk
              • May 2018
              • 12
              Re: konica C454e
              when I ping I get reply, it does print. using chrome when web browsing, says err conn timed out.
              could web browse in the shop till it was delivered and customers network people got to it.
              reloaded firmware, cleared memory
              • tsbservice
                Field tech
                • 8028
                Re: konica C454e
                Did you try what Synthohol suggested?
                You can also try to slow down NIC's speed, if it works then your machine's NIC could be the culprit.
                • kttyhwk
                  • May 2018
                  • 12
                  Re: konica C454e
                  What is PSWC?? looked in network and can't find.
                  • blazebusiness
                    • 1257
                    Re: konica C454e
                    Page Scope Web Connection On many Konica models you :
                    From the
                    [UTILITY] screen, go to [Administrator Setting] - [Network Setting] - [NIC Setting] - [HTTP Server Setting] and check whether [PSWC Setting] is set to [Enable]
                    But 1st try an alternate browser
                    • greglogston
                      • Jul 2018
                      • 34
                      Re: konica C454e
                      Seriously try using a different browser.
                      • Vikingrepairguy
                        • Mar 2017
                        • 21
                        Re: konica C454e
                        Clear your browser cache
                        • Engr Josh
                          • Jul 2018
                          • 2
                          Re: konica C454e
                          Check IP address if it has changed after updating the firmware
                          • emujo2
                            • Mar 2017
                            • 1579
                            Re: konica C454e
                            Check to see if SSL is enabled. There are various security protocols and if something less than what your browser supports has been used, the connection will be refused. If this is the case (since you didn't respond with the HTTP browsing setting ON/OFF). You will need to do another HDD format to clear the certificate. Once done and if SSL is required, ensure you choose 2048 SHA-256. Remember printing, scanning, ICMP (ping) all use different ports then the web browser, so you can also play around with telnet to verify 80/8080/443 are open on the MFP. Emujo
                            • rrrohan
                              • Sep 2011
                              • 1977
                              Re: konica C454e
                              Might be a IP conflict
                              Turn off copier and see if you still get a response
