Konica Minolta 283 software switch 25
  • pdy-pt
    • Mar 2018
    • 58
    Hello together!
    can anyone tell me the standard Hex Assignment of Switch No. 25 on a Konica Minolta 283? I did not write it down when I reset the NVRAM.
    Thank you!
  • Synthohol
    Certified Konica Expert
    • 5861
    Re: Konica Minolta 283 software switch 25
    It's in the firmware document depending on what version you loaded
    • pdy-pt
      • Mar 2018
      • 58
      I loaded G00-D6 but unfortunately in the Word file is nothing written about SSW 25. Which PDF file do you mean?
      • Synthohol
        • 5861
        wow, its not like the 4 series in the respect of switch 25, i cant find a single document that shows the levels anywhere on the xx3 models.
        im sorry, i really thought they would mention it once other than 1 doc that said "take note of hex assignment as it will be reset"
        i dont see them too often but if i spend time in the lease return pile maybe i can dig one up.
        • pdy-pt
          • Mar 2018
          • 58
          That would be great if you could look it up!!!
          Thanks!
            • 14873
            According to the BH283 in my shop the default for soft switch 25 is hex 20.
            • pdy-pt
              • Mar 2018
              • 58
              Perfect that worked!
              Thank you!
              • antone
                • Oct 2014
                • 344
                Same Here
                Sent from my SM-N950U using Tapatalk
