bizhub C3350 Error 9303 no duplex
  • druckerteam
    • Oct 2015
    • 28
    [Error Code] bizhub C3350 Error 9303 no duplex
    Hello.
    We have a bizhub C3350 with the error 93-03.
    If we want to print or copy in duplex the paper come out, but in the lower output, like we print simplex.
    Normally it should come out in the upper output and then the paper go back in the printer and the second page will be printed. But the sheet come out completely and after it come out we have error 93-03.
    In the device is a motor which moves and "change the way the paper should come out, but we dont have another machine to change this motor.
    Do anybody know the reason?
    Regards, Paul
  • JDR
    • Jan 2015
    • 82
    Re: bizhub C3350 Error 9303 no duplex
    same issue, anyone got an idea ?
    • druckerteam
      • Oct 2015
      • 28
      The problem ist the duplexer motor. It was defect.
      • DK-tech
        • Apr 2021
        • 25
        No such motor. Can you remember more precise wich part?
        • tsbservice
          Field tech
          • 7912
          Maybe it's 93-03 see below:
          1.4.15 Misfeed at duplex transport section
          (1) Contents
          JAM type
          JAM code
          93-03
          Detection timing
          93-03
          The duplex transport sensor (PS6) is not blocked even after the set period of time has elapsed after the
          paper exit sensor (PS7) is unblocked by the paper.
          In case the duplex transport sensor (PS6) is unblocked after main power switch is turned ON, door and
          cover are opened / closed or jam/trouble reset is done, it is regarded as paper jam at duplex transport
          section.
          In case paper position is detected as locating properly after main power switch is turned ON, door and
          section.
          Misfeed processing
          location
          Duplex door
          Relevant parts
          • Main motor (M1)
          • Fusing motor (M2)
          • Duplex feed clutch (CL4)
          • Duplex reverse clutch (CL5)
          bizhub C3850FS/C3850/C3350
          K TROUBLESHOOTING > 1. JAM DISPLAY
          K-10
          • Duplex transport clutch (CL6)
          • Duplex transport sensor (PS6)
          • Paper exit sensor (PS7)
          • Printer control board (PRCB)
          (2) Procedure
          Step
          Action
          Control signal
          Location of electrical component
          1
          Initial check items
          2
          PS6 I/O check, sensor check
          PRCB CN11-11 (ON)
          15-G
          3
          PS7 I/O check, sensor check
          PRCB CN14-16 (ON)
          15-K
          4
          CL4 operation check
          PRCB CN12-8 (REM)
          15-D
          5
          CL5 operation check
          PRCB CN12-10 (REM)
          15-D
          6
          CL6 operation check
          PRCB CN11-8 (REM)
          15-G
          7
          M1 operation check
          PRCB CN9-3 to 6
          15-B
          8
          M2 operation check
          PRCB CN9-9 to 12
          15-C
          9
          Replace PRCB
