KM C224 Non "E" Control Panel Question
  • fadsamniote
    • Apr 2016
    • 80
    Hello !
    Everybody knows that customers break the "flat cable" from Non "E" Series from KM C224/C284/C364/C454/554 Series...
    I know that Konica Minolta have a firmware to put funcions of C224e Series on "NON E" Series ...
    To prevent from break the screen I want to lock the screen and put keyboard on screen like C224e Series ...
    Can anyone tell me what firmware version it is or simple switch a "DIP SWITCH" in CE MODE. I'm KM dealer soo have acess to firmware plataform.
    Thank you all.
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: KM C224 Non "E" Control Panel Question
    I'm not sure what you mean by the flat cable breaking since we've never had that happen. From day one, we locked all the control panels to the left so the hard 10 keys were always visible (never even telling the customer that sliding it was an option). That way the customer can't even slide the control panel back and forth. To lock it, there is a place to put a screw on the back of the control panel.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • fadsamniote
      • Apr 2016
      • 80
      Nice Ideia ... Never thought about that.
      Any way If I could lock the screen in normal position and add the NUMPAD on screen like C224e it will be great.
      • tech51
        • 846
        • copyman
          Owner / Technician
          • Sep 2005
          • 4718
          Most of my customers with the NON-E C224 don't even know the display slides to the left with a keypad behind it!
          • eccelobo
            • 113
            Same in Argentina
            Enviado desde mi SM-G920V mediante Tapatalk
            • Copier repairman
              • Aug 2019
              • 86
              A161291-F000-GD3-03
              KM C224 / C284 / C364 시리즈 펌웨어의 비 "E"시리즈.
              C224e 시리즈와 같이 화면에 키보드를 배치합니다.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4718
                Also I've seen more Non-E machines locked in open position exposing hard keys than locked closed having to use digital keypad. I've never done it but the ones I've seen just had a self tapping screw on inside so it couldn't slide closed.
                • avecosat
                  • Jun 2012
                  • 305
                  The firmware is GB3-M0 C224 to C224e
                  • emujo2
                    • Mar 2017
                    • 1579
                    This only upgrades some of the network protocols. IE SMB V2..It does not allow you to start putting E series parts in..Ed
                    • tulintron
                      • Jul 2014
                      • 668
                      It only needs the firmware that makes the numeric keypad appear on the panel of the NON model And the same appears on the E models. I've seen this before but I don't remember the firmware. If I find out, I'll send you.
                      • B0265
                        • Jan 2007
                        • 718
                        You need the "version up" fw, GBx-xx, as avecosat wrote.
                        • enricocopyline
                          • Jun 2018
                          • 122
                          Originally posted by Copier repairman
                          A161291-F000-GD3-03
                          hi copier repairman
                          I sent you an email has it arrived? my address is jones3@hotmail.it
                          • Synaux
                            • Mar 2012
                            • 1224
                            I assume this is the same as with the bigger 4 series:
                            I believe this FW is actually on KM website for the public under drivers.
                            Also, do not try to go directly to the "e" FW. IF you do, you will need to use the special downgrade FW then go to the latest base FW and so on.... Big headache especially if you don't have access to Konica Confidential.
                            • emujo2
                              • Mar 2017
                              • 1579
                              Oh my..please don't start that rumor..There are no firmware files available on the public site..E
