Wierd fixing problem in konica c6000
+ More Options
Posts
  • sadanand
    • 62
    I am getting wierd fixng problem .only front side of copy small patch not getting fixed .I replaced lower roller,lw roller bush ,1/2 roller ,1/2 roller bearings but the problem is still there ,any suggestions ?
  • Toxic
    • 698
    Re: Wierd fixing problem in konica c6000
    What is condition of fusing belt?
    Some photos of prints,fuser,... could not hurt to post here.
    • sadanand
      • 62
      Sorry sir ,attaching file ,appreciating your quick response
      • Synthohol
        Certified Konica Expert
        • 5888
        a halftone or solid test pattern would be more helpful that the 2" thumbnail even when opened.
        please use fullsize images.
        • Toxic
          • 698
          I agree,post sample with more color and bigger size.
          Try rotating fuser belt,i think you will see damaged spot.
          Fuser belts on this machine starts to falling of at 400-600k prints.
          • methogod
            • Dec 2008
            • 922
            Why is the image hosting here so bad? makes posting photos harder....
            agree belt is damaged...
            most damage occurs at the 8.5" 11" 12" marks depending on what they run.
              there should be a "defect ruler" or "repetitive mark" ruler in the service manual... measure from the top of one mark to the top of second compare spacing to ruler... replace offending part.
              • sadanand
                • 62
                Dear Sir Thanks All For your kind Help Problem Solved.......Repalced Fuser Belt...Thank Once again
