BizHub C280
  • randallcraig
    • Aug 2018
    • 3
    BizHub C280
    Hello from Las Vegas,
    Need some assistance obtaining firmware for a BizHub C280, troubleshooting a C-C186 error. Any assistance would be greatly appreciated.
    Thank you.
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: BizHub C280
    A dynamic link error occurs in the program on the MFP board due to an insufficient memory space available, a
    ROM fault, or other reason when the main power switch is turned ON.
    Relevant electrical parts
    MFP board (MFPB)
    NVRAM board (NRB)
    try to reseat the ram and NVRAM. if that does not change anything replace the MFP board.
    what was done prior to the code?
    • randallcraig
      • Aug 2018
      • 3
      Re: BizHub C280
      Thank you for the quick response. Customer stated moving the machine and bumped the wall. So I will take a look at your recommendations and get back to you.
      Thanks again!
      • cristachecri
        • Mar 2015
        • 31
        Re: BizHub C280
        Hi all .
        I have a question about the question: the DR311K black drum unit (for Konica Minolta Bizhub c280) is much lower than the DR311YMC color image units.
        What differences exist between these image units ???
        It is very clear that the price differs.
        Theoretically, when I need to change the image, then I would have to order 4 black units and solve the problem. Who can tell me about this question, please beg me to answer.
        • Synthohol
          • 5849
          Re: BizHub C280
          Theoretically the click charge cover getting the correct consumables without playing silly 'mod the unit" game.
          Especially on a deader than dead model. Sounds like it's time to renegotiate the contract so you can afford the right OEM parts.
          I'm not trying to sound like a jerk, I just don't comprehend how to rig consumables for the purpose of greed.
          When a model is dead like this one your company should consider dropping it or charging more.
          Just my .02
          If it's discontinued we only offer a labor only contract and customer buys the consumables.
          • 907tec
            • 434
            Re: BizHub C280
            IIRC, all you have to do is buy the Y/M/C chips and install those on the DR311k drum unit. Even with the cost of buying chips (assuming you don't rewrite them yourself), there is a considerable cost savings.
