Bizhub 367 , Code C5307
  • pinspin
    • Oct 2011
    • 156
    [Error Code] Bizhub 367 , Code C5307
    Hello, Bizhub 367 appeared code С5307 that we did not find in the service manual. Maybe someone has a description of this code? Thank you.
  • tsbservice
    Field tech
    • 8013
    Re: Bizhub 367 , Code C5307
    Are you sure it is not c5370? Anyway check your fans.
    • pinspin
      • Oct 2011
      • 156
      C5307
      • copyrooks
        • Oct 2013
        • 209
        No go on the manual. I was looking through other model's service manuals and i stumbled upon code C-5307 on a Bizhub C3350. Related to the UFP Fan Motor (FM5) which does exist on the bizhub 367. Its a long shot but hope it helps
        • docdot69
          • May 2016
          • 53
          Try to check in the service mode>system2>3rd page Cleaning Unit. If its ON but not installed, turn it OFF. I know it sound ridicolous, but i had an issue, after firmware upgrade, the cleaning unit went ON by itself. Just made it OFF and the problem gone.
          • pinspin
            • Oct 2011
            • 156
            Switch 25 solved the problem
            • CopierNerd
              • Feb 2015
              • 207
              Could not guess what this guy did? Changed the switch 25 hex assignment after firmware upgrade? or it is related to the solution of error code c-5370 fan motor?
              • Selcuk Ozuer
                • Jan 2025
                • 1
                thank you exact solution
                • rosaro75
                  • Mar 2009
                  • 87
                  It perfectly working. Thanks
                  • sklanarong
                    • 1
                    Thank you very much.
