654e
  • antone
    • Oct 2014
    • 344
    654e
    Partly transfer text on copies...tried DV unit,drum,fuser,nothing broken on duplex door or transfer unit.....transfer belt looks good!
    Sent from my SM-N950U using Tapatalk
    Re: 654e
    did you electrically test the contacts?
    are the transfer rollers inside ITB moving up and properly?
    could the contacts for the transfer section be dirty/bent?
      • 23008
      Re: 654e
      Maybe the pressure lever is broken?:
      • antone
        • Oct 2014
        • 344
        Re: 654e
        That's a good call....but HV 2 fixed this one !
        • Bix
          • Apr 2018
          • 1421
          Re: 654e
          HV is Power Source ?
